JCR Race Pipe Vs Soul Modular System: the good, bad and ugly
#77
https://rennlist.com/forums/991-gt3-...t-bracket.html
Soul commented on how to support GMG center section with their side delete. They recommended using Mikalor Band Clamps to fit around the CMB and the Lower factory tab. This may be the solution here. But maybe would need to hook it up to the upper tab give the curved pipes on the JCR.
Here is a photo:
Here is a photo:
#78
well then....the JCR looks like it has brackets that attach to the area of the OEM side mufflers.
we are just trying to find a quick fix for those that are having issue with the drooping of the tips if the proper tightening of the header clamps doesn’t solve the issue.
#79
#81
^^^ Shouldn’t be that hard to do...the oem center attachment is right there. Hopefully JCR will do this as I will hold off for now on purchasing their exhaust.
#82
I dont have the sagging and am a few stouts in, but i think I previously read that mounting the center with a rigid mount may result in transferring nv that isn't optimal. I'll be keeping an eye out for this sagging. By the way, and this is a bit silly, but does anyone else like seeing the JCR bazookas in the rear view camera?
#83
lol
I have a race pipe listed for sale, but something about all this discussion...i think i may just keep it, it has reminded me how good the sound it. I know i will want to put it back on soon. I was selling bc i do not need more attention from CA police right now! I do not have the bazookas but want them, beautiful tips.
#84
Haha, after reading this thread yesterday morning, I took my car out for a 2 hr. drive. It was hot AF! But I still had the windows rolled down so I can get the full experience of the car and sounds. The sounds this exhaust (Ti Valved Race Pipe) makes is simply amazing! Sometimes I can't tell much of a difference between the valves closed or open but it was more noticeable yesterday. Checked the pipes after getting home and no drooping (never had an issue anyway)
I love this car...it was ~ four weeks since I last drove her. Incredible car and its ability to put a smile on your face. Drive and enjoy boys.
#85
I just adjusted mine . Loosened the pipe clamps first , then tried to adjust but it wouldnt budge . Loosened then the header clamps and i was able to move the tail pipes a good inch or so upwards using my jack.
torqued the header clamps 16 ftlbs and the pipe clamps 25 ftlbs . Mine is a silenced race .
#87
Even if it is torqued as spec I believe having some sort of center support will add a significant amount of lee way before the tips move. Just my thought.
#88
I could be wrong but to me it sounds as if the header clamps are just under way too much pressure trying to support the center muffler regardless of the clamps being torqued correctly no?
#89
#90
aren’t you negating the effect of the JCR support bars by doing this? Loosening the header clamps (post cat) and pulling the entire cat back system up to bring the tips closer to the diffuser basically compresses the rubber bushing and adds more strain to the header clamps and gasket.
I feel this will move again ; mine moved with regular street use - about 3k miles
