Fire Extinguisher question?
Looking to mount a FE under the front passenger seat. Already checked with my Porsche dealer and they say Porsche has stopped selling the optioned kit as an accessory for my car. From looking around all I have found is Rennline which looks like they have a good mounting frame for the CF buckets along with a race approved quick disconnect mount that looks well engineered. At this point I am planning to buy these units as I have not seen any alternatives. My question is specifically about FE size, is the 1.4 lb sufficient or should I go for the 2.5 lb.? I am leaning towards the halotron agent FE. Does anyone know which size came with the FE original option on the 991.2 GT RS cars?
I'm pretty sure you want the 2.5 pounds. I installed the Safecraft PB2 (2.5 pounds) in my Huracan. Also Halotron has half the efficiency of the gas in the PB2 (Halon 1211). SafeCraft makes units for Aviation, Marine and Motorsports. I spent some time looking into this on Aviation and Motorsports forums. It's not cheap but worth it. I also tried to get the factory equipment from the dealer and it's nearly impossible as they don't ship it to the US if the car didn't come equipped with it. I need to order this same setup for my RS and install it. Just haven't done it yet.
The following 2 users liked this post by RoyalPink:
paddlefoot64 (07-31-2020),
usrodeo4 (07-31-2020)
asking for a friend. How many people have ever NEEDED a fire extinguisher??
Went with the Rennline EZ Adjust mount - well designed, easy to install.
HalGuard Clean Agent 2.5
And used the standard mount. Although the $275 Rennline quick release would be very nice.
The following 2 users liked this post by matttheboatman:
