Tuning your GT2RS? What are people going with?
Congrats on the GT2...they offer an other worldly driving experience. As to tuning, I am keeping mine OEM for the near future (mine is a 2019 so two more years of warranty) and as of my thinking now I may keep her OEM for as long as I own her. But if I was going to start making H.P. upgrades, the first thing I would start with is the CSF/PWR intercoolers and as BBi has built packages around them they would be on the top of my list when I started doing serious due diligence. As others have said if you are looking for track time improvements I think the upgraded intercoolers would still be my first upgrade but after that upgraded suspension and aero upgrades, and braking (SS lines and track pads) would be where to look...or realistically for most of us, professional driving instruction. The full Manthey Racing MR kit is ~ $83K without the MR BBS magnesium wheels.
CSF by PWR High Performance Porsche 991 GT2 RS Intercooler System - CSF Racing (csfrace.com)
--nevermind - didn't see the link. Much appreciated.
Another option people have employed is sending their car out to countries where Manthey sells and shipping it back.
I did this to my GT2RS:
- Front underbody clubsport (same as MR)
- KW competition 4way MR
- Front tension arms E-Motion engineering
- Underbody streaks from E-Motion (not convinced of their effectiveness)
- Front Clubsport canards
- PFC full brake system front and rear from Levitas
- 19 Forgeline wheels with my specified custom offset
- Pirelli slicks
- Rear Clubsport wing, side plates and uprights (need some work to fit the lid, you need the rear Clubsport carbon bracket also $$)
- Clubsport SRO kit
- Custom modified rear diffuser reversible to stock
- 200 cell cats
- Custom tunes from Sambo & M Engineering, several iterations and testing for my specific needs were required. All mild tunes
Getting alignment, ride height and shocks (compression/rebound) dialed in exactly for my needs was painful but is perfect now. MR settings are a good base but of course they dont work for all the tracks, you will need to fine tune.
All the above is fully reversible, done it twice already in and off season.
Feedback..
My lap times with stock wheels and Cup2R were very similar, might be my driving but I wouldnt do slicks and 19 and cost associated with them.
Clubsport rear wing induces very high drag (I measured including front underbody and rear modified diffuser the following:
Clubsport Cd: ~52
Stock: ~36,
MR: ~42-44 including their rear wheel hub covers
If you run on tracks with fast straights I wouldnt do it, aero drag offsets gains in downforce.
Lap times with stock wing were faster on two F1 tracks, my modeling and simulations also confirmed it. I took out the CS rear wing and its in storage now.
Best bang for the money from my own experience is:
1- Custom tune
2- Tension arms
3- Rear modified diffuser (<100 Usd)
4- Front underbody Clubsport
5- Suspension
6- Brakes
Similar setup in good hands was faster than all the GT2RS MR cars
- Pirelli slicks
- Clubsport SRO kit
- 200 cell cats
Feedback..
Clubsport Cd: ~52
Stock: ~36,
1- Custom tune
2- Tension arms
5- Suspension
6- Brakes
pepinozaur (06-22-2022)
Tune - even if I dont plan for it now how is it? How much boost? Advance timing? 100-200.. etc
Tension arms - what are they good for?
rear modified difffuser mod - what is that exactly? do I need more front DF to compensate, like maybe CS front?
the rest I guess is quite clear to me
To answer the topic, even I thought to be doing more modifictions, I am still on a mild setup.
Here are my mods so far:
- MR OEM suspension upgrade - it seems some secret sauce added to the front uprights and shims on all 4 corners. I added MR allignement, rake adjustement etc to compliment the hardware add-ons
- MR water tank extension
- MR braided brake lines
- Girodisc 410/390 and PFC08 brake pads
- Maxxed aero front and rear - removed front wheels air guidances, front fender grills, rear wing in max attack
- Used cup2 n2, but having already 2 sets of Cup2R to try next
- I will upgrade 6 point harness to enduro version as they seem to be easier to engage/disengage
My car is a clubsport without WP, so maybe I will add the Ti rollbar and Magnesium wheels to shave 24kg or so
The 100-200 on my road and conditions dropped to 5:02s vs 5.47s for stock.
The tension arms make it easier to setup the Caster, I also think they help the geometry overall. I got them from E Motion.
The diffuser, I simply removed the stock channels and had some custom aluminum ones designed and fitted replacing the stock ones. I made them lower and longer towards the back, close to the Manthey specs probably.
I have not tried running the rearGT2RS CS wing without the front CS underbody, so I cannot verify whether it would cause understeer in real life. But I do run the carbon fiber CS front underbody, both with the stock GT2 wing and with the CS wing, and the car is very planted either way.
In stock mode I had a 619whp run and another 636whp. Tuned I had around 715whp if I recall, this was running zero (no) timing retardation on the track.
I had stronger tunes but we dialed them down, mostly the torque, for better drivability and heat management. This is where a friendly tuner is most important when working remotely, Sam and M-engineering did 9 or 10 iterations with different maps and testing until it was according to my preference and track. I am sure a straightline tune could bring better numbers.
Thanks, good to know. Yes totally agree on philosophy for road course tunes. The hi output dyno tunes are ok for drag, but sounds like you and Sam are getting fitting targeted results. Kudos
Basic Sponsor
Feel free to reach out anytime. We’ve had some great success with the GT2RS cars and we are even doing a ByDesignXR on one now!
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
Just Manthey suspensions is a game changer on the car, also with Cup R or slicks.
I drive the full Manthey GT2 RS often on the Nurburgring, and suspensions were the biggest changer.
If you need infos about it, or a provider to ship it to you, let me know
