Porsche Ti Roll Bar Install is DONE!
#31
I have had an issue with the factory glue I used...the panel leather came loose around the trimmed area after a test drive to operating temperature on a mid 90 degree day. After doing some research I have ordered a dual compound interior glue with a much higher temp ceiling. Glue to arrive Monday. I have also spoke to a body shop/interior shop in Central Fl., that is Porsche approved and I may take the panels down to them Monday with my new glue to look at my work and see if they see any product quality or craftsmanship issues. I will take some more pics when I have her back together as the finished product. At this point that is my only thing left on the To Do list
#32
USRodeo4
Nice going it looks like the modding has begun source those MR rear Aero disks.
Ian
Ian
#33
That is exactly the reason why I asked. I think that it is not that simple to cut a hole through. In order to make the hole look original, the plastic needs to be cut through and the leather should have a flap that wrap around the opening of the hole. If the plastic and leather are cut line to line, de-lamination will be unavoidable worse case or cosmetically no good best case.
#34
OP, you should begin to follow RobertLinton1 on Instagram if you havn't already. No doubt you would enjoy his posts.
usrodeo4 (05-18-2021)
#35
lol, I understand the fluid dynamics of the aerodisks but Good Lord they are ugly. That is not a mod I could do...but I do like the lighter BBS motorsports mags As the Roll Bar is OEM I don't really consider this a mod, just righting the table that FDOT kicked over in the first place.
#36
Thanks and yes I have spoken with Bob before...he is a great guy and sharp as a tack. A real renaissance man if you will. He knows a lot more about the 2RS than me and is also wired in pretty heavily with the Defense Industry and U.S. Military. When we talk shop I am very careful to watch the words that come out of my mouth as I am sure Bob is too.
#38
#40
I think Archimedes (at least the name implies it) is smarter than to risk his neck with amateur installations and unproven equipment purpose.....your testing wouldn't pass basic never mind rigid engineering standards... Your driving - I can't say. You coffee tastes seem to rank highest with your dislike of Starbucks.
#41
As an added note for anyone considering tackling this, one other tidbit; the rear (front section) of the carpet where the front of the roll bar bolts in, is already precut from the factory for the roll bar but if you use the carpet as it comes it leaves a minor space; the carpet "circle" doesn't quite complete to close the gap. To get a perfect "seal" from the carpet you will need to slightly trim the carpet. I decided to install mine without trimming the OEM carpet so if you look closely you can see one partial bolt showing on both sides. As I said it could be remedied by slightly trimming the carpet to allow the circle to be closed but I made the decision to not trim the OEM carpet. I have never seen an OEM Ti bar car so not sure if theirs look like mine or if the carpet is slightly trimmed on the factory floor to get a perfect fit around the front bar. You really have to look to notice...some day if I ever see a factory Euro spec WP Ti bar car and they have no gap I might go ahead and do a quick trim job to make mine the same but for now I am going with the OEM trimmed carpet.
#42
#43
That said, the roll cage looks great and I don't doubt that it's plenty safe.
#44
@usrodeo4 does the back of the seat come into contact with the bar at all if the seat is in it's furthest back setting? If not, do you have the seat reclining brackets installed? I ask because I have the GMG harness bar in my 3RS, with seat reclining brackets, and it touches the bar (and has marked the seat back). I'm eyeing a 2RS and thinking of finding a factory bar to install like you have done (nice job by the way). I won't bother though if it's going to contact the seat like the GMG bar has done and make a mark in it. Thanks.
#45
Member neoprufrok has the titanium roll bar installed as well though.
You are not the only one who has issues with the GMG roll bar touching the back of the seat: https://rennlist.com/forums/991-gt3-...rness-bar.html
WhySock (03-26-2023)
