Nankang CR-S on a GT3 old CR-1
Just having these fitted.
Superstiff side wall. They are a track tyre.
CR-S is a street tire, it's a 200tw max performance tire. The Cup2's and AR-1 are both track focused tires.
I would not take the CR-S on a track day, they most likely will start to overheat and not last long.
But on the street, or AX the CR-S is the best tire you can get on a GT3.
The following 2 users liked this post by DiscoWagon:
daddyrabbit (07-11-2022),
flsupraguy (05-25-2023)
Are you speaking from experience having driven all 3 tires on a circuit? From my experience, the CR-S is way stickier, heats up faster, and can put down more consistent laps than the Cup2 on a sub 2 minute road course. 200tw doesn't mean a thing these days, it's a category that allows tire manufacturers to produce very fast tires to meet "200tw" class requirements.
On my local tracks, I can get over 1.5g on cup2's, and pretty much stay there all day long, temp and pressure stabilizes, unless I overdrive the car.
On CR1 max G is around 1.44, however, CR1's are much better at putting power down, they work better then Cup2s in a straight line grip, but lack a bit in lateral grip. They also have less feel and slower turn in. However, they are also nice and progressive, and I can let the tail move around more with them. But they start to overheat quicker and grip falls off. They also do not last, I get almost 1/2 the life out of the CR1 vs Cup2, but the CR1 is also a bit cheaper.
For me, the CR1 is my AX and drive around tire (quieter, smoother, better in wet and low temps), and the Cup2 is my track tire. That's what has ben working for me. FWIW, my last set of rear CR1's lasted about 2500mi, and are getting swapped out this week.
I've been going through sets of Cup2 with my last set of rears delaminating during the first event last year, so am really happy to try out a "budget" alternative. Went with the OE size CR-S 245/305 20" set up for my first DE event this year and was very happy with the performance. Biggest issue for me was pressure swings: laps 2 and 3 were excellent, then they gradually got greasier due to rising temps. I started off at 26/27 F/R and typically ended at 39/36 F/R. Fronts have seen temps at 40C coming into the hot pits for quick pressure checks. I can feel the tires get greasy, and a quick peek at the TPMS gauge confirms the reason, and my session is pretty much done. Next session would be about 50mins later, and pressures come down to high 20's. Yes, lots of late/heavy braking involved but I didn't get these types of temps with Cup2s. On the street, TMPS generally report +4PSI all around when "hot" on the CR-S. Any of you guys experiencing similar swings?
Setup: OE Carrera S wheels, AP road & track f/r BBK with DS1.11 pads all around, Tractive suspension. -3.1F and -2.1R camber (need to get a rear kit) (Oh and this isn't a GT car, just a T)
Other than the temp issue, I'm really happy with the tires; better grip than Cup2, and just enough audible to keep me posted on what's going on. Turn in isn't as sharp/quick as Cup2 though, but it's a non-issue to me. I'd continue using these, durability over heat cycles has been better than Cup2 (12 so far).
991.1 GT3 Intermediate/Advanced driver.
I have been a long time Michelin fan but found the Cup 2's lacking in wear and longevity on the track. The Cups were greasy in 20 heat cycles. I was very disappointed.
Surprisingly, I have found the NANKANG CR-S's to be OUTSTANDING! I'm on my 2nd set. First set stayed sticky for 9 HPDE days and had meat left on them, even then. Bought them from Phil's Tire Service and the last set I had heat cycled. Predictable, sticky and long wear. My wet experience was disappointing but it was some serious wet so Ill probably give them another try.
I have kept a log on each heat cycle and the performance vs. psi. I'm finding my best feeling and rotation at 30/31 psi FULL HOT. Sometimes I'm going out at 24 psi cold first run of the day and I simply do 3 laps @ 7/10's staying off the kerbs, then hammer it.
Camber=-2.9 front/-2.5 rear
Toe= 2 out front/2 in rear
Bars set 2 front and rear
I am not affiliated with NANKANG or Phils but dang happy to have this option.
I had always felt like I was headed for Hoosiers. Now, I'm not so sure.
+1
+1
konrad h1 (06-04-2023)
I ran Cup 2's and then Dunlops and then AR-1 on 991.2 GT3RS. Went through 3 sets of AR-1 as they were far superior to the other two tires. I recently got a 2020 AMG GTR Pro and am bummed the AR-1's arent available in OEM sizing. Cup 2's are and the CR-S's are as well so I'm going to try out the CR-S and hope for the best!
konrad h1 (10-30-2023)
@ParadiseGT3 Based on your experience with CR-S V2 on 991.2 GT3, do you recommend to keep OEM size or go one size bigger based on PTS chart:
265/35/20 and 325/20/20 seems to be a better fit for OEM GT3 rims.
Thanks for the input as I am planning to replace my Cup2 early next spring with CR-S
ParadiseGT3 (10-31-2023)
Personally would not go with those bigger specs.
Basic Sponsor
NANKANG DEALER HERE!
Contact us for any tire inquiries!
-Josh
-Josh
Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more
Orange County, CA
Email: info@merakiautoworks.com
Text/Call: 213 394 2886
Website: www.MerakiAutoworks.com
Orange County, CA
