Can break loose center lock nut, any ideas?
I originally posted this in the 992 Fourm ..Any additional ideas are appreciated. carl
https://rennlist.com/forums/992-gt3-...-lock-nut.html
I had a similar issue on my first GT3. I could not break it with the Precision Instruments breaker bar. I'm 5'6" and was using the roughly 3.5' breaker bar. My 6'6" buddy came over with an 8' breaker bar. He broke it loose quick and easy with that combo.
That was right when I got my first GT3. I have never had the issue again, as I maintain the CL mechanisms properly.
Like others suggested, try lifting the bar using your legs, not pushing it down. It’s safer that way anyway. Also try extending the handle it using a pipe or a floor jack handle. An extra foot is all you need. Can you get someone to help you?
I bent my breaker bar getting one of the wheels off on the weekend so careful.
Before I got the torque multiplier I used a six foot pipe extension on a HF type breaker bar. Bent it up a lot. I don't really know the conditions that make that nut so hard to loosen, but do know it can take 600+ ftlbs to loosen at times.
latest in the never ending saga. Sea Post 49 Carl
https://rennlist.com/forums/992-gt3-...l#&gid=1&pid=3
if all else fails
https://www.milwaukeetool.com/Produc...tening/2867-20
the 1 inch high torque impact is what we use on the gt3 cup.
Just read through your thread on the 992 forum. Good for a few laughs with some of the posts.
I use the Precision tool kit, same as the one you just bought. I set the breaker bar parallel to the ground and stand on it. If the nut is still stubborn, I gently bounce up and down on the bar. Technique has not failed me yet. Granted I'm 200 lbs to your 150 lbs, but the extension bar you are waiting on should do just the trick.
EDIT: Make sure the CL tool is fully inserted and that the CL lock depresses easily. Did have one one time that the lock would not depress, requiring a gentle tap with a hammer to depress and unlock it.
While driving it around go to the dealer and let them deal with it. If something goes wrong they're responsible.
If you have enough game you may even be able to get them to do it with no appointment. Even offer to pay if necessary... like for rotating tires.
