991 GT3, GT3RS, GT2RS and 911R 2012-2019
Manthey Upgrade Kit OEM Suspension - GT2 RS
Old 08-23-2022, 04:34 PM
juanpablo046
juanpablo046's Avatar
Default Manthey Upgrade Kit OEM Suspension - GT2 RS
Hi,
Anybody tried already the OEM Suspension upgrade kits from Manthey?
I'm looking to install one on my GT2 RS but I don't even have the OEM alingnment range specs to compare to the MR ones.
Manthey part number is MTH343222
Old 08-23-2022, 04:57 PM
pepinozaur
pepinozaur's Avatar
I am running that, what would you like to know?
Old 08-23-2022, 05:04 PM
juanpablo046
great!
If you have what parts where included and what's the recommended height and camber setup would be great.
Old 08-23-2022, 05:43 PM
pepinozaur
pepinozaur's Avatar
shims front and rear - from Cup cars I supose
some "secret sauce" top-mounts upgrade
allignment, rake adjustments using 4 corner weight scales, simulating your weight etc
settings are based on personal preference, I did mine for the Nring, for GP tracks, it should be a bit lower
the car feels good, very good, but maybe not exceptional, like the full MR.. I would do it again if this means something to you
juanpablo046 (09-03-2022)
Old 08-23-2022, 05:45 PM
juanpablo046
Thanks!
I'll basically order the parts and have them installed at my local Porsche Dealer. I'll just order the kit and figure it from there, thanks
Old 09-02-2022, 12:44 AM
CX_GT3
CX_GT3's Avatar
How big of a difference are they over the standard suspension that came with the car? What are you noticing the most? Any changes to daily driving comforts (harsher/softer rides)?
Thanks in advance
Old 09-02-2022, 06:04 AM
Taffy66
Taffy66's Avatar
The Manthey KW 3-4ways fixed dampers transform both GT2 and GT3 RS on track. The GT2 RS also benefits a lot from the Manthey full aero pack, more so than the GT3 RS..
Old 09-03-2022, 05:36 AM
pepinozaur
pepinozaur's Avatar
It makes some difference vs oem and 100% stock allignment. Wider track and sporty allignment definetely helps a lot
The rake, they are running the car even higher than it used to be, I have Nurburgring setup but still...
Also bellow 7:40btg, the front tires will touch a bit the body, there are some marks on the tires as well. Never happened before on any other track or above 7:40..
No, exactly the same comfort, maybe even a bit more clearance to the ground?! I bought my car slightly used, so I dont know if factoy height is what I used to have or not, but the setup is very compliant on all surfaces.
Thanks in advance
Please see above
CX_GT3 (09-07-2022)
Old 09-03-2022, 10:56 AM
scottchuk
scottchuk's Avatar
I'm getting this kit installed at Manthey at the end of the month - hope it's as good as described
Old 09-05-2022, 01:08 PM
juanpablo046
I just received my upgrade kit from MR, I hope I'll have it installed this week.
Does any one have the OEM alignment and height recommended settings? to compare to the MR ones.
Old 09-07-2022, 06:21 PM
CX_GT3
CX_GT3's Avatar
Please see above
Thank you very much for the detailed answer to my questions! I'd be saving money for a set now haha
Old 09-10-2022, 08:38 PM
Maxi_z
Maxi_z's Avatar
Did you get any explanation about the improvement of those top mounts spacers and what the black rount parts are for ?
Old 09-10-2022, 11:14 PM
juanpablo046
Yes,
Manthey has been very helpful recommending a setup according to my specific needs. They also include a detailed installation description.
They say you can have camber up to 3.0 front and 2.8 rear with this kit.
Old 09-11-2022, 04:59 AM
pepinozaur
pepinozaur's Avatar
This is what I am running now -3F and -2.8R, and I feel, from a street vs racing allignment point of view, that they could go much more and still not eating tires.
Old 09-11-2022, 08:11 PM
juanpablo046
They recommend toe 1mm per side on front and 2mm per side rear, stock is basically 0. I'm pretty sure with that it will start eating tires.
Quick Reply: Manthey Upgrade Kit OEM Suspension - GT2 RS
