FAL stuck in up position
My front axle lift won’t come down, neither with the button nor by exceeding the 30mph threshold. I have the message “Lift system fault Service required”. Is there a way to default it to lower or reset it? Am at a track day and no shops anywhere close here.
Post EDIT: so I went a ran it over a cattleguard on a local road a couple of times, and when I stopped again the warning message was gone and the drop button worked as normal. I’m afraid to test the lift again in case it gets stuck, will try it when loading the car back on the trailer after the track day.
The following 4 users liked this post by dsteding:
The following 5 users liked this post by numnut:
abiazis (05-16-2023),
Brainofjjj (05-16-2023),
cscrogham (04-22-2024),
Jimmyk79 (05-12-2023),
rockhouse66 (05-09-2023)
Well, it happened again. Came in from a 20 min session, and when I slowed in the the pits the warning message came on again and the axle lifted… without me having pressed the button !
Tried the cattleguard again, tried disconnecting the battery for a few mins, put my 210 lbs in the the frunk, but problem persists. The owners manual does not identify a fuse for the FALS so not sure how is disable it if I could get it to drop down one more time. Is there a way to manually relieve the air pressure in the pneumatic system?
was hoping 991 system worked
Just to close this out ands provide for future reference, the quick fix was to disconnect the FALS air lines (braided SS) from the bottom of each front shock (there’s an Allen bolt mount), drive around the parking lot, and re-connect. FALS has been functioning fine ever since, but still not sure what caused the original gremlin. According to a tech, it’s tough to disable the FALS (at least in the pits!) since the fuse is not readily reachable (its part & parcel of the FALS compressor assembly deep up inside the tranny hump) and the relay is under the driver’s seat.
konaforever (04-21-2024)
Never. But you highlight a good question, it’s possible when I lowered the FALS on the trailer after strapping the car down that the front straps did not allow it to settle 100% all the way down. It’s a clearance I did check and it was tight.
Larry Cable (04-21-2024)
I wonder if you have a loose electrical connection that's shorting out on the FAL system, (while I don't play an automotive electrician on TV), the behavior is somewhat consistent with that... just my $0.02! either that or this is another "pressure sensor switch" issue akin to that we diagnosed on the 997's...
I’ve only had one issue in the 4 years with my 991.2 GT3.
It was the FAL. Failed and had a warning similar to yours. Warranty replaced FAL motor (can’t remember exact part). . Has worked fine since.
Good luck.
Good luck.
FAL and Suspension System Fault
I have a 991.2 GT3 and after a week of not driving it.
I get a FAL fault paired with a Suspension System Fault.
I’ve searched the forums and haven’t seen anyone get the same paired issue.
Has anyone encountered the same issue? At least together. I’ve seen lots of FAL faults but not with the suspension system code too.
FAL is stuck in the up position and sport mode is deactivated. Just trying to wrap my head around it.
Basic Sponsor
It's good to learn of potential issues, too. Thanks for posting.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
