991.1 GT3 worn wheel bearing?
Looks like just rust on the outside… if there’s no side to side motion, then it’s probably fine, and just rusted from your living near the ocean, or from water getting behind the rotor during an aggressive car wash.
The following 2 users liked this post by WP0:
justint5387 (05-20-2023),
Larry Cable (06-28-2023)
I just hope its not the differential
[QUOTE=Flo89;18811042]5000 km ago all 4 wheel bearings where replaced. Now, after 2 Trackdays one of them looks like this:
Is it f***** up?[/QUOTE
Do you drive it on salted roads or near the ocean?
And were the new bearings OEM or aftermarket?
If there's grinding, then it sounds problematic. You don't want to drive on those, if that's the case. bearings on a GT3 are a bear to change out. Is it possible that they weren't properly installed, or you used refurbished parts?
Update: its not the wheel bearing
other side looks similar, so I think its part of the manufacturing process.
Maybe driveshaft/differentail/gearbox.
Hopefully the dealer will find out.
Redsled83 (05-22-2023)
The following 2 users liked this post by Palting:
Flo89 (05-21-2023),
Update:
The clicking noise doesnt come from the wheel bearing
Cold start, idle:
https://youtube.com/shorts/bXlU5ORy844?feature=share4
I have a guess: The starter hits the flywheel from time to time.
Cold start, idle:
BruceT (06-29-2023)
