Brake fluid flush
I don't put any fluid in the pressure bleeder. This saves on wasted fluid a little and makes clean up easier, but does require additional disconnects and re-pressurizations to top off the reservoir.
There's one bleeder, I think it's on the inboard side of the front right corner, that will not accept the 11mm flare wrench. It's like the casting on the caliper doesn't allow enough clearance so I have to use an 11mm socket. Makes things a little messy.
And after two non-working Motiv bleeders out of the box, I gave up and bought a different brand that was less money and has a better construction.
My box wrench reaches all 8 bleeders without issue. And a box is preferable to a flare wrench for something like this (with a moveable vinyl hose that can be placed through the box - only really need them for hard lines…)
Right - box end wrench with the tube through the wrench to the bleeder. I also purchased like 4 feet of tubing at the hardware store and run it into a large plastic jug sitting on the ground rather than a shorter tube to a commercial bleeder catch bottle hanging from the car and getting in the way while working.
I’ve used the Motiv that way also, but it is very risky (can easily introduce air if you don’t keep very vigilant at monitoring the fluid level in both sides of the reservoir).
9914s (04-17-2024)
No need to keep refilling Motiv during a bleed if filled enough, but you do the other way…
Basic Sponsor
I always blow out the bleeder after I'm done with brake clean.
I've had fluid that resides in here after the job boil out on the track and stains the caliper.
--Aaron
--Aaron
GrantG (04-17-2024)
krell (04-18-2024)
I’ve had several (probably half a dozen or more) of the Black Label 019 Motivs and each has been perfect
