991 GT3, GT3RS, GT2RS and 911R 2012-2019
US Configurator
Old 04-04-2013, 01:26 AM
  #91
Cupcar#12
Cupcar#12's Avatar
Humm, 95ah battery (if correct and i don't see why not with rws)
something like this.... It's 26.4 Kg---- Max voltagefreaks is 45ah..currently.
Brand: Bosch
Trade name: AGM HighTec 595 901 085 95 Ah
Length : 353 mm
Width: 175 mm
Height: 190 mm
Capacity: 95 Ah
Cranking amps: 850 A
Accumulator terminal allocation: “+” on the right
Maintenance: not require
Manufacturer: Germany
Warranty / Service: 24 months
Price per: pcs
Brutto, package size: 26,4 kg
Old 04-04-2013, 02:46 AM
  #92
Mike in CA
Mike in CA's Avatar
Originally Posted by stevencr
Very helpful info. I'm pouring a new driveway this weekend for the 977.2 RS. I assume your approach angle for the RS is without the Front Lift. Any idea what the angle would be with the Front Lift activated? Guessing around 9 degrees...
Originally Posted by StirlingMoss
Yes, those numbers are without front lift. No idea what the angle is when lifted. Sorry.
Maybe you can calculate it: FAL raises the car by 30mm......
Old 04-04-2013, 03:25 AM
  #93
Petevb
Petevb's Avatar
Do you know if the axle lifts 30 mm, or the nose? Some quick numbers give me 7.2 degrees with a 30mm nose lift, 7.9 degrees with a 30mm axle lift.
Old 04-04-2013, 05:23 AM
  #94
StirlingMoss
StirlingMoss's Avatar
As I understand the lift is measured at the axle. The nose measurement would (obviously) depend on bumper, spoiler lip, etc.
Old 04-04-2013, 01:26 PM
  #95
Mike in CA
Mike in CA's Avatar
Porsche describes it this way:
An optional lift system at the front axle raises the front end by 30 mm. Operable up to a speed of approximately 50 km/h, it minimises the risk of grounding on kerbs, ramps and car park entrances.
I guess it depends on how you interpret "front end".
Old 04-04-2013, 03:58 PM
  #96
StirlingMoss
Yes, this is open for interpretation
Some more details:
"The function module is a compact unit located at the front of the centre tunnel and is approx. 80 cm long. The pneumatic compressor generates pressure of up to 20 bar if required. The pressure reservoir has a fill volume of approx. 1 litre and stores the pressure required for the system to function. The compressed air system is controlled by means of a valve block unit. The system weight of all components of the front axle lift system is approx. 7 kg."
Old 09-15-2014, 12:48 AM
  #97
az audi
az audi's Avatar
The ground clearance at the centre of the front axle is 93mm (3.66in) which is exactly the same as the 997.2 GT3 RS.
The approach angle in the front is 5.8 degrees versus 5.6 degrees for the 997.2 GT3 RS.
The ramp break over angle is 5.1 degrees versus 10.3 degrees for the 997.2 GT3 RS.
Is this compliant with your favourite coffee shop parking lot?
Can you tell me where you found this information? Trying to find a ramp solution for my trailer. And I assume the approach angle is based on a single plain, not open in the middle? If the middle is open, do you happen to know how much more the angle is?
Quick Reply: US Configurator
