Lightweight Bucket Supply causing GT3's to be pushed.
#497
Mike, remember that the anti sub bar that we use in the old GT2 buckets are aftermarket bars made by BK and not Porsche. Porsche never made antisub bars for the GT2 seats. I have always wondered about how the harnesses were mounted from the factory, but Macca has shown that they bolt to the floor from the factory (better way to do it anyway).
Just as a point of interest (well, it's interesting to me anyway) Porsche did provide mounting bars for the earlier one-piece Euro GT3 seats. I still have one of mine; they came as a pair and the other one was in my 996 when I sold it.
#498
I don't thnk cutting a slot in the pass seat will be too hard. Copy the same outline from the drivers seat, drill a starter hole to get a jig saw blade in and saw away. PIA....nothing seems easy between this and the roll bar.
#499
Agree, but cutting a slot in the cushion is another matter too...
#501
I believe the pass seat has a web shaped electronic position/weight sensor under or in cushion for passenger side airbags. Cutting in middle to provide a belt slot would probably be a game ender to the system and trigger the warning lights on for good and prevent airbag system from working properly?
#502
Isn't the seat cushion two pieces like the drivers side held in by Velcro ? If not, that is a shame. I should of spec'd the standard seat and bought aftermarket to avoid all this nonsense. I wonder if the seats are standard in the RS ? If not, maybe I will get that car with standard seat and buy after market Sparcos....and trade in my current 3 due to arrive in January.
I suppose we can blame the Neanderthal US DOT agency
#503
Isn't the seat cushion two pieces like the drivers side held in by Velcro ? If not, that is a shame. I should of spec'd the standard seat and bought aftermarket to avoid all this nonsense. I wonder if the seats are standard in the RS ? If not, maybe I will get that car with standard seat and buy after market Sparcos....and trade in my current 3 due to arrive in January. I suppose we can blame the Neanderthal US DOT agency
#504
Well maybe a custom seat upolstery shop could cut and stich a hole nice and neat. I am concerned about how to deal with that weight sensitive airbag sensor in the passenger seat. What a buzz kill. I should of ordered sofa's.
#505
Couple of pics below, hard to get at the moment as it's in a pretty dimly lit garage so can't get a picture looking directly at the seat to focus.
I think the carbon fibre is a pretty good match, not perfect as the seats are a bigger weave but I think it's the best interior combo still. If you stare at it long enough the control console looks different to the dash, and the door, but I think it's really size of the weave more than anything.
About 2" of travel - maybe a touch more.
U
U
#507
Just a couple of things. In the ROW clubs port fitment the belts are situated with a loop and buckle situation after if the centre position in order to avoid the possibility of the belt binding. These are installed in accordance with FIS regulations I'm fairly sure.
Secondly the gt2 seat cushions u have appear to be two piece with the belts running up between the two sections though I have to confess I haven't removed them to be sure. They look outwardly very similar to the 918 seats.
Lastly I would imagine those holes are the ideal location points and it wouldn't be too difficult to weld in the threaded nuts if needed after all that's what the rest of us have had to do with older 911s for many years.
Cutting out the cf at the bottom of the passenger seat now that's an unknown put looks doable...
#508
My thoughts on the padding below the headrest: I'm assuming it's a DOT issue for children. The cushion is at neck level for me and doesn't touch me while seated. I suppose it's padding for the back of a child's head as that's probably where it would be for children not needing car seats but are still below adult height. I can't think of any other reason it should be there. I guess they added it for the drivers seat as well to keep it symmetric.
#509
Since the Speedster, Porsches with racing type buckets have been more highly valued. The new GT3 carries forward this tradition with what is an "almost" racing seat that is highly functional. Take a look at anything in the GT3 class or less, and nothing comes even close. You want these seats now and definitely in the future for your collection.
#510
Disculpa...
Mira Eduardo, no comments, mejor me callo por no acabar mal antes de conocernos.... Lo de la conquista a lo mejor reconquistamos California nosotros antes.... Yo por lo pronto me voy a Las Vegas la semana que viene por si quieres invitarme a ese Ribera y curas un poquito esa prepotencia
Lo que creo que pasa es que no estoy haciéndome entender muy bien a través de estos 'posts' en Rennlist. Necesitamos hablar en directo y entonces puede ser que compartiremos en puntos de vista. Lo de los asientos 'sport bucket' espero que entiendas mejor lo que trate de explicarles a todos con el post #358.
https://rennlist.com/forums/991-gt3/...pushed-24.html
De veras que no entendiste lo que dije en el post #358?
Y a California te la regalo si la quieres...pero a no ser que tengas tu mas sangre de Cuauhtémoc que de Rodrigo Díaz de Vivar, en verdad no veo como harás para reconquistarla de la manera que va todo esto de 'fronteras abiertas', a lo bien o a lo forzado! Acuérdate lo que paso con la 'Marcha Verde' del Rey Hassán II de Marruecos en Octubre del 1975 en El Sáhara Occidental. Yo vivía en España en esa época y recuerdo muy bien el mal rato que pasamos todos preocupado por los Españoles (soldados y ciudadanos) en ese territorio en Africa. Y aunque se salvo algo con la famosa 'Operación Golondrina', todo me dejo con un sabor en boca bastante desagradable. Y creo fue algo que también disgusto al pueblo Español! Yo no soy de los que piensan que fronteras no importan. Si que son necesarias! Y ojalá que puedan ser respetadas tanto en Ceuta, Melilla y el Estrecho de Gibraltar como en los estados de Tejas, Nuevo Mexico, Arizona y California!
Favor de disfrutar a Las Vegas y espero vernos cuando estes de paseo por esta zona! Por ejemplo, si vienes a Rennsport V el proximo Octubre!
Saludos,
Eduardo
Carmel
