First wash... any tips
Maybe he's someone who's never owned an expensive car and wants to make sure he doesn't damage his investment. Maybe some other reason. Who knows. Who cares. Are you the guys that punched smaller kids on the playground?...why come pick a fight...?
wolves, sheep, sheep dogs....
My GT3 was delivered last week on a rainy day so it's been dirty from the get-go. It will finally be nice enough for a wash this weekend... I've got the 2 bucket system with grit guards, microfiber wash mitts, and an electric leafblower for drying. I still need to pick up a hose/pressure gun. Could anyone recommend some pressure guns/kits they use or ones to avoid?
1Z Einszett Wheel Cleaner (if you don't have CCBs)
Griot's Rubber Cleaner for tires
CarPro Pearl Tire Dressing
Two Buckets
Optional: Foam Cannon
Sheeting Method Rinse
Leaf Blower Drying (People are 50/50 on this. I dislike the Master Blaster)
Dry while Spraying Adam's Detail Spray
If you're super board and have several hours of your life to waste, click on the links in my signature to see how I do it. My method is stolen largely form Phil at Details Domain and Mike Phillips from AutoGeek, but it's not the only way to do it.
Everyone will have the products that they use(d) and work for them.
Two bucket for sure with grit guard at the bottom. Key is to use a lot of water/foam and a clean mitt. If you do not rinse the mitt out enough you will get micro fine scratches on the paint. Plenty of GOOD microfiber towels. You get what you pay for in microfiber towels.
Once finished, I would polish and wax the car to keep it looking as clean as possible. Use a detailer mist in between washes (but be careful to not use when you really need a wash vs touch-up--again clean micro fibers for this process).
Any who, everyone has the products they like--for me I use Chemical Guys. Have found their microfibers great and the polish and waxes are some of the best I've used. But when it comes to products it's like choosing a car color.
Good luck and whatever you do, don't ever run that car through a car wash.
I'll check out Chemical Guys for Microfiber cloths; thanks!
Does anyone use a quality Chamois for drying?
I use a waffle microfiber, the guzzler (green ones from autogeek). Some guys use white cotton towels.
I haven't seen anyone use a leather or synthetic chamois in quite a while. The chamois doesn't have any depth to the face to absorb any solids that might be on the surface during drying.
Also avoid the California blade, unless you want a scratch in the shape of an arc. These poly blades will eventually get something hard embedded in the edge and a catch horribly.
Ryan
Ryan
Ryan
Ryan
Thank you.
I'm going to try Optimum Instant Detailer next time, but have been using Ammo Hydrate in the past which I liked.
Great movie.....
Master Blaster over leaf blower. Master Blaster uses heated filtered air and eliminates any need to hand dry. Leaf blower can suck up and throw out dust. You can go straight to polishing and waxing with no hand drying with Master Blaster.
Anytime you need to rub rather than pat during drying spray some quick detailer on the area first.
Ryan
For washing, I do the following:
1) Add car wash soap in bucket
2) Fill bucket with warm water so my hands don't freeze off since it's winter time in Portland
3) Soak a fresh microfiber towel in bucket
4) Rinse car with a liberal amount of fresh, Bull Run water
5) Wash car with soap and water mixture
6) Rinse car with a liberal amount of fresh, Bull Run water (yes, I do this twice)
7) Dry car with fresh micro fiber towels
8) Put it back into the garage without a care about that water spot because I am not saving my car for the next owner.
Small 1500 psi pressure washer for 1st rinse.
Soap dispense with pressure washer and dunce again. No need for nit or towel to touch paint. Master blaster to dry and Griots spray wax to finish with microfiber towel. Done!
Thanks for the feedback guys. I have a GT Silver car so it doesn't show swirls/scratches like something darker. Funny comment about the sheep dogs... just saw that movie last night and I enjoyed it.
