Hoosiers
Hoosiers
I get so many PM's and emails about running hoosiers on the 991 GT3 that I would just like to make a post so others can easily search and get the correct information. There is also some poor information floating around here which can be corrected.
Hoosiers on the 991 GT3 work perfectly. We have run them for several events with zero issues or problems and the results are as expected. Amazing!
Here are the only sizes that work. Do not run other sizes
Fronts are 265/35/19
Rears are 325/30/19
Currently hoosier makes the front in R6 only and the rear in R7. R7 is the replacement to R6. There is no problem or issue running this combo. No problems with ABS, RWS, TC, etc. No problem with R6's or R7's on the Gt3. Hoosier will make the R7 in the front size sometimes this year. R7's have a stiffer sidewall and require less air pressure than the R6. Figure 3 pounds less hot. I like hot pressure at 35-36 for R6 and 32-33 for R7.
The rims are BBS 19's and are stock offsets. You must run rims in the stock offsets or as close as possible. 1 or two mm won't make a difference.
Here is a post I made last year about mods to the rear lower control arm to get the 19's to work along with info on the shims
https://rennlist.com/forums/991-gt3/...-prep-diy.html
If you have any questions please post them here so others can learn. I'm here to help in anyway I can if you want to run hoosiers on your GT3. There are no secrets or magic formulas to run these tires. If you have tried to run the sizes posted above and you find that your lap times are slower there is something wrong and its not with the tires. That would be the driver or the setup and both of those can be easily fixed!
Here is a picture since we all like pictures
Rears are 325/30/19
Former Vendor
GT3 player par excellence
I ran Spartans comfig, same wheel same tires (based on his pioneering efforts)
they work
clearance is tomy
no scraping yet
I hit every berm I can hit
they work
clearance is tomy
no scraping yet
The LCA mod is not so bad and I wouldn't let that deter you from running 19's
Essentially the stock rear wing isn't high enough to do all that much. The crawford wing addresses this and totally changes the car. Much more planted in high speed turns and it gives you the confidence to keep the throttle down. My track mechanic set up the car at the track after putting on the wing and per his suggestions we went with a rake to address this. This fixed the front end looseness and push at turn out under throttle. Overall our car went down about 10mm rear and 15mm front height wise.
Please let me know if you have any other questions on the wing!
