P11 Lightweight Bucket Seats -- How to recline the seat angle
Wordsmith
I assume the process is a matter of bolt holes in the bucket to allow for different angles. It's not immediately obvious just eyeballing the seats.
I could potentially shim the bolts under the sliders, but that's generally not much and compromises attachment (and it's a weak kludge.)
Anyone with experience been there, done that?
GT3 player par excellence
there's a button.
or you can have tony drill stuff.
or just get used to the vertical position like i do and then suffer lower back pain. THAT is the GT3 experience.
^ she did, but i practice architecture for 10 years. my upper back is fk as i droop over drafting table (yes before cad). my lower back is even worse from mt bike racing and crashing..... so if you see quasimoto on your next trackday, that would be me
Wordsmith
In any case, I've fiddle around. It's not the upright so much (which is quite good, it's the deep lower back gap and forward shoulder pads (and weird "neck pad" ?) that are awkward.
My next step is to rip out the seat cushion and see if that changes the geometry. I've fiddled with the (limited) adjustment. Why Porsche put in electric height adjustment, I dunno. I guess someone didn't get the "lightweight" and decided on more iron.
Anyway, I don't mind elongating/slotting the brackets -- I've done that since the 90's, it's just a bit feeble for a 2015 911 with all-wheel steering to need Dremel to get the seat adjusted ... : )
Either you're referring to the hunchback or Google says there is a rapper (?) with that name.
Post some pics if you follow through with doing this.
I had a similar problem on my prior car with GT2 seats. When wearing my helmet and HANS, they would hit the back of the seat in the headrest area. I had Tony install spacers under the front mounting bolts to tilt the seat back a few degrees. Worked great. The seat mounting bolts are long enough to handle the spacer, so I never gave it a second thought after trying it.
Bad design by porsche. Ferrari racing seats have recline lever. Was hoping they fixeD This issue by now
Wordsmith
I need more than 70 miles on the odo to comment about correct driving position. I think with helmet on, it will be fine (because the headrest seems to give more space and less padding there, but a test fit is not the same as the out lap to settle into a good driving position.
Does anyone happen to have the part number of the sub belt cross bracket?
Is the passenger side seat not mean to have a cut-out for the sub belt? (bizarre ... and would cause trouble for PCA instructor belts rules, etc.)
At first blush, I have to ask, as Moot describes it, what kind of Quasimodoesque child of Fukushima Sushi-eating parents could possibly sit in these seats and declare their bowl of porridge to be not too warm, not too cool.
There. Enough mixed metaphors to catch up on the long break between posts to Rennlist.
Wordsmith
Well, "dad stuff" has taken the priorities of late ... damn moral compass ... and I need break-in miles on the odo, so I won't be making it to TH anytime soon, but I am looking to sneak over the bridge to Sears during the week, so keep me posted on the next GT3 drive. The first item on the shopping list is 19 wheels and Hoosiers while I figure out the seating arrangements. Alignment out of the box is pretty dead. Still scratching my head about updating the Movits. DAS Sport bar (?) Cup wing. The usual stuff.
I'm 5 foot 7 inch and my 2011 Boxster Spyder CF seats gave me a similar problem with lack of lower back support which made me wish for an incline adjustment.
The lumbar support part of the seat was to high for my back and so it actually pushed my mid back forward making the seating position seem even more vertical.
I ended up mostly solving the problem by stacking two pieces of carpet pad foam cut to shape between the seat shell and the seat cushion which lifts up on the Spyder. This had the effect of raising me up in the seat an inch or better and suddenly it fit much better lessening the need for an incline adjustment.
I don't know if the bottom seat cushion will lift up on the GT3 lwb or not, but if it will it's a cheap and transparent fix. Couple this with drilling new seat frame holes for a slight rake change and you might be in seat heaven.
Subscribed.
Great to read you on these threads Adam.
I also had the front mounting points of the seat rails raised on the 997's as far as it would go without hitting the (carpeted) contact points of the roll bar too hard.
