991 GT3, GT3RS, GT2RS and 911R 2012-2019
Car Trailers for GT3
Old 07-02-2015, 12:21 AM
thxbuff2001
thxbuff2001's Avatar
Default Car Trailers for GT3
I am seriously getting a trailer to be able to bring my toys to the track without having to pay a hauler.
Any recommendations? Can be open or closed.
Old 07-02-2015, 12:34 AM
Todd B
Todd B's Avatar
For open trailers, look at a trailex CT-8045. Bought one a few years ago, after having a steel trailer for years, not sure why I waited so long. The long ramps makes loading easier.
awew911
awew911's Avatar
I tow an ATC Quest CH305 with my F-250 (w/Reese Sway/load balancer). http://www.aluminumtrailer.com/produ...dCarHaulers/65
Purchase a set of Rennline Tie Downs.
Used to have an open Featherlite towed by my previous tow Expedition.
Any specific questions, I'd be happy to help.
Old 07-02-2015, 12:48 AM
thxbuff2001
I wonder if they are light enough to be pulled by a Nissan pathfinder or GL450? Thats a nice trailer
Old 07-02-2015, 12:49 AM
thxbuff2001
Did you have to buy extra long ramps?
Old 07-02-2015, 12:53 AM
az audi
az audi's Avatar
Where are the straps connected?
I have an open Jimglo tilt trailer using over the wheel MAC nets. All works good. A little difficult to push the nets in but better than the through the wheel straps I use to use.
Old 07-02-2015, 12:57 AM
awew911
awew911's Avatar
I had ATC fabricate the ramps for me. It's a common option they offer. The just fold up and secure to the door.
As for the tow vehicle, I wouldn't recommend towing this particular enclosed trailer (7000# loaded) with anything less than an F-250. I tried towing it ONCE with my Expedition (9000# tow capacity). When I did tow it with the Expedition, I saw G-D when being flanked by 18-wheelers. I traded in the Expedition for an F-250 the next week.
Old 07-02-2015, 01:03 AM
awew911
awew911's Avatar
The fronts connect at the jack points and the rears connect just foward of the transmission. Takes 15 minutes to install. I used to use the MAC wheel nets in addition to the 4 tied down straps but found that to be a little overkill.
Cross the tie downs across the front and also the rear.
Rears
http://www.rennline.com/Rennline-Tie...oductinfo/E37/
Fronts
http://www.rennline.com/Rennline-Tie...oductinfo/E36/
Old 07-02-2015, 01:09 AM
thxbuff2001
This is going to be an expensive hobby.
Old 07-02-2015, 01:13 AM
thxbuff2001
Rears
Fronts
How easy is it to open the car doors when it is inside the trailer?
Old 07-02-2015, 01:30 AM
awew911
awew911's Avatar
It's not. I lay a towel down on the door so when I open it, I don't hit the wheel cowling. Then I move the seat all the way back and slide out. It isn't fun, but I only have to do it twice during the weekend.
Some people install a SuperWinch S5000 with remote and 'walk' the car up the trailer.
Old 07-02-2015, 02:32 AM
forhamilton
forhamilton's Avatar
Atc is tops. I have a steel enclosed, but it is really heavy and they don't hold value.
Trailex is tops for open, but expensive. I bought a Nextrail. Good quality all aluminum and 25% cheaper.
Old 07-02-2015, 02:40 AM
montoya
montoya's Avatar
This, you will scuff or scratch something eventually.
Warn winches are IMHO the best, especially with a synthetic rope and the remote is fantastic. Just walk it up!
TPD trailers are the best and hold their value. Below is my setup. Please also check out 24Chromiums Trailer Diary!https://rennlist.com/forums/racing-a...ler-diary.html
Old 07-02-2015, 02:56 AM
thxbuff2001
What do you use to pull the car and trailer?
Old 07-02-2015, 02:57 AM
mlpor
mlpor's Avatar
How tough is your tow vehicle?
http://www.bre2.net/mm5/merchant.mvc...e=car_trailers
Quick Reply: Car Trailers for GT3
