991 GT3, GT3RS, GT2RS and 911R 2012-2019
GT3 - TPC Side Muffler Delete
Old 10-05-2015, 03:14 PM
biglare
biglare's Avatar
Default GT3 - TPC Side Muffler Delete
I have reviewed several threads on Rennlist and finally decided to install the TPC side muffler delete option. This retains the factory exhaust valve switch to direct exhaust to the stock rear muffler section. Notice the void where the side mufflers used to be which saves over 40 pounds vs. stock. The sound is incredible and with the switch you can choose the sound to be mild or wild!
Enjoy some quick photos from the install, a quick vid from Thunderhill track day and I'll try to get more videos up soon.
Special Thanks to Alekshop for the install.
File Type: mov
Old 10-05-2015, 03:28 PM
Jimmy-D
Jimmy-D's Avatar
Received 1,399 Likes on 725 Posts
Can not wait to here it. I like the idea of retaining the functionality of the valve switch
Old 10-05-2015, 03:50 PM
doba_s
doba_s's Avatar
rear tires will run much cooler now too!
now that you saved weight it's time to add a harness bar
Old 10-05-2015, 06:48 PM
bigkraig
bigkraig's Avatar
Do you notice the valves opening/closing when driving around? I've got straight side muffler deletes now and would like to be able to calm it down sometimes.
Old 10-05-2015, 08:17 PM
biglare
biglare's Avatar
I use the exhaust button as before, but the difference is the exhaust is now louder in both modes as the side mufflers have been removed. It is nice to retain the stock exhaust to tone it down when desired. This may be exactly what you are wanting.
Old 10-05-2015, 10:40 PM
Jimmy-D
Jimmy-D's Avatar
How is the drone?
Old 10-06-2015, 12:50 AM
sechsgang
sechsgang's Avatar
Originally Posted by Jimmy-D
How is the drone?
ditto
Old 10-08-2015, 07:14 PM
biglare
biglare's Avatar
Originally Posted by sechsgang
ditto
There is very little drone when cruising around the city and no drone when on highway. As for the track.... it sounds GLORIOUS!!!
Old 10-08-2015, 08:12 PM
odwa
odwa's Avatar
Not sure about you biglare, but I've had the side muffler delete for over 5k miles and there was some drone in the beginning, about 3k miles ago they seem to have "broken in" and there is absolutely no drone now. My side deletes are Fabspeed with valves and are exceptional!
Old 10-08-2015, 08:16 PM
biglare
biglare's Avatar
I've only had the side muffler delete on for less than 500 miles, so I'm thinking that with more miles the slight drone that I have around city driving will start to disappear with more miles.
Old 10-08-2015, 08:35 PM
bigkraig
bigkraig's Avatar
why would a couple of pipes with valves on them break in?
Old 10-08-2015, 08:44 PM
biglare
biglare's Avatar
In my case, I don't think it is the side muffler delete as much as it is putting some miles on the entire exhaust system. I just clicked over 1,000 miles so far. I absolutely love the sound and would highly recommend it for anyone that wants to lose some rear end weight and gain some volume!
Old 10-08-2015, 08:48 PM
ZZinger
ZZinger's Avatar
I currently run the sharkwerks bypass. How does the side deletes compare to the sharkwerks as far as volume goes?
I like my sharkwerks but sometimes want it louder
Old 10-08-2015, 09:02 PM
biglare
biglare's Avatar
I'm not sure how the sound compares as I have not heard the sharkwerks bypass setup in person.
I'm guessing if you have the sharkwerks side muffler bypass, then it will sound very close if not the same as my setup when I have the valves open.
If you have the stock side muffler and the sharkwerks rear bypass section, then I'm not sure how the sound compares.
Hope this helps.
Old 10-08-2015, 10:26 PM
allans
allans's Avatar
Can you leave the valves closed at high RPM if you want to?
Quick Reply: GT3 - TPC Side Muffler Delete
