991 GT3, GT3RS, GT2RS and 911R 2012-2019
Complete RB CCM Brake Kit for 991 GT3
Old 05-12-2016, 08:12 PM
RacingBrake
Former Vendor
RacingBrake's Avatar
OE caliper vs. RB caliper
OE pad vs. RB pad
RacingBrake is offline
RacingBrake
Former Vendor
If you DIY and replace the brake pads often (or as needed), I believe you dislike the awkwardness of OE caliper's close top and well miss that open top convenience
This is how you replace a brake pad. Note the caliper is on our work bench and it can be turned to any way we want just to get the pad in. Imagine you have to detach the caliper from the spindle and it has a hard line attached, and work under the fender.
Spring must be in first
Then pad in, this is where the struggle is...
We have the caliper on bench with screw driver, after prying and pushing we thought it's done...
But take a look at this - The hold down spring is tapered, so after all that we still mis-align the spring to the pad nub...
With RB calipers pad "check" and "change" is so easy; 2x M6 pad bolt, and 1xM10 center bolt is what you have to deal with.
Old 05-12-2016, 08:15 PM
RacingBrake
Former Vendor
First front kit being shipped to a 993TT customer - Thank you Royjo A. for your support.
Rear kit is to follow in a few days.
Old 05-12-2016, 10:07 PM
Basal Skull
Basal Skull's Avatar
These are going to be hilarious on my car! can't wait..
Basal Skull is offline
Old 05-26-2016, 07:08 PM
RacingBrake
Former Vendor
Default Rear kit for 993TT is shipping!
Rear kit is shipping today:
Rear rotor (390x32mm) weight:
Composite rear hat has an iron sleeve (inner) for emergency brake:
Back side view:
Caliper weight (brake pad and adaptor are pre-loaded):
Caliper (front view) - Bleeder valve is tagged (pointing up) for easy installation:
Caliper (top view) w/open top for easy pad change:
Old 06-15-2016, 11:25 AM
RacingBrake
Former Vendor
We have a CCB thread here for BMW M3/M4
RB-CCM Brake Kit for F8X M3/M4
This answer to one of the members there about the CCM rotor cost may be helpful to you.
Originally Posted by racingbrake
MSRP is subject to consumer/dealer discounts, so ~$1,500 to $2,000 each is about right depending on where you get them. Total car set $6,000 - $8,000
This is the reason why we like to use GM parts in building our CCM brake kits for Porsche owners.
In comparison:
997 pccb front rotor set $11,500
http://www.suncoastparts.com/product...735103293.html
997 pccb rear rotor set $10,600
http://www.suncoastparts.com/product...735203201.html
Total 4 rotors (car set) $22,100
Porsche 991 CCM brake system upgrade (including calipers) $29,700
http://www.suncoastparts.com/product/GT3991PCCB.html
How they compare with BMW CCB?
RB complete CCB system including brake pad and brake line $14,982
http://www.racingbrake.com/RB-CCB-Sy...ccb-por-01.htm
Old 06-28-2016, 08:12 PM
RacingBrake
Former Vendor
Bulk CCM discs in stock for quick shipment.
ZR1 Front Discs 394x36mm:
ZR1 Rear Discs 390x32mm (In foam packs)
Surface Transforms Discs (various sizes):
See this same RB-CCM kit installed in the 993TT.
https://rennlist.com/forums/993-turb...l#post13405482
We stock replacement CCM rotors and OE pads so they can be shipped quick with price lower than what you can get from GM dealers.
Old 08-19-2016, 03:07 AM
RacingBrake
Former Vendor
Replacement CCM rotor cost:
They cost only about 1/4 of pccb, better yet you don't have to wait for weeks or months from Porsche dealers - We stock them for the same day dispatch - guaranteed.
Buy from GM dealers and replace the discs yourself, or purchase complete new assembly from us then send the used rotors back later for core (hat) credit.
Details see description below the item link.
RB makes CCM brake more affordable and keep your maintenance cost in check so no more fear of replacement costs and save more money than standard iron brakes in the long run.
No rust, no dust, no fear brake that your 991 deserves.
http://www.racingbrake.com/RB-CCB-Sy...ccb-por-05.htm
Old 04-11-2017, 05:47 PM
RacingBrake
Former Vendor
Default Caomplete CCB Options for Porsche
https://www.racingbrake.com/category-s/7200.htm
Old 05-10-2017, 11:02 AM
RacingBrake
Former Vendor
Looking to lighten your iron rotor weight (upgrading to CCB)
http://www.racingbrake.com/RB-CCM-Re...por-crk-01.htm
Or want to preserve your pccb (switching to Iron), or replacing your OE/Aftermarket Iron rotors, we have them.
http://www.racingbrake.com/category-s/7345.htm
Rebuilding your OE calipers with RB caliper components and make them perform better than OE.
http://www.racingbrake.com/category-s/7379.htm
Transform your 991 brake into a complete CCM brake system for lower running cost and maintenance/replacement cost.
RacingBrake is an innovative brake company with emphasis on fundamental material science, design and metallurgy.
The most comprehensive brake shop for your 991.
- All parts (including CCB brake system) are in stock for prompt shipment -
Old 11-15-2017, 01:25 PM
RacingBrake
Former Vendor
John J - A Mustang GT350R track driver has found RB CCB rotor on sintered brake pad, replacing his OE iron rotors and pads, to be the optimal track set up that provides a "bullet proof" performance with lasting durability.
Carbon Ceramic Brakes - They're on!
It's time for an update on the CCB's. After running them for three track days and four months of highway and city service, I wanted to give the folks who wondered about my sanity an update ;-).
It turns out that I'm sane. I have to say that I put these on with some trepidation - the internet knowledge base said they would be fragile, that they couldn't handle track use and they'd be nothing but an expensive headache. My experience is the EXACT OPPOSITE. I love them. I'm never going back to iron rotors. These things are that good.
First, for track work, they are flat-out phenomenal. I've run them with both RB sintered pads and with Pagid RSL-29's. To help with thermal management, I put the Cooltech brake duct completion air deflectors on and I used titanium shims to protect the brake calipers. After my three trips to the track, I still have healthy caliper piston dust boots and the ATE Typ 200 fluid worked fine. Now, I could have upgraded the stock Brembo calipers with RB's stainless pistons and high temp seals and used Castrol SRF. That would have given me even more thermal capacity, and for racing you'd want that, but for me as a casual track day guy, I wanted to see if that level of prep was needed, and it wasn't.
The sintered pads are a new product and they're "streetable" in the sense that you can run them all the time if you want to, but they're a bit noisy. As for bite, they've got the bite of a tyrannosaur. Mu is around 0.60 and it's immutable. Same brake feel from cold to glowing hot. Most racing pads have a mu curve that you ride up and down as the brakes heat up and cool down. These things are always the same. As for dust and wear, well there's no dust and almost no wear. After three track days, the total pad thickness (two pads pressed face to face) had gone from 34.0 mm to 33.6 mm. I'm not particularly hard on brakes, but it looks like those pads will last a long time. And what's really interesting about the sintered pads is the transfer layer (see photos in this thread). Basically, the pad lays down a metal layer and that becomes the friction surface for braking. So, not only do CCB rotors outlast iron rotors with composite pads, with sintered pads, the metallic transfer layer renews itself as you use the brakes. So, the long-lasting rotors will last even longer.
One of the criticisms of CCB's in the past has been poor modulation. My experience with sintered pads and with the RSL-29's is that they're just as easy to modulate as any other brake system. Now, the high-mu sintered pads give you a lot of braking with moderate pedal pressure, but once I got used to the sensitivity, I stopped thinking about it and got on with driving.
If you want to know more about racing with CCB rotors, Google "David Donohue Pikes Peak brakes" and you'll find videos (one is on the DSC Sport Suspension website) showing David Donohue's run up Pikes Peak in this year's hill climb event. He's Mark Donohue's son, by the way. Anyway, the Google search will turn up a review that David wrote and posted on a forum (that's why I didn't provide the link) about CCB brake performance with sintered race pads on the Pike's Peak race car. Apparently, he likes them too.
The Pagid RSL-29 pads are approved by Pagid for CCB track use. That means they don't crumble when they get hot as some composite pads are known to do. They have less bite than the sintered pads, and they work great too. They are still on the car, and after a couple of months of driving around town with them, they're remarkably good as a street pad. Super quiet, good braking and virtually no dust. Another winner.
I also ran the OEM GT350 Ferodo pads for a couple of weeks just to see what happened. They worked fine - they were a bit dusty, but nothing like they are on iron rotors. I didn't take them on the track, and I don't plan to. I've got everything I need with the RSL-29's and the sintered pads.
So that's the update. This was one of two rewarding upgrades I did on my GT350 this year. The second one is the DSC Sport Magride controller. It's amazing too, and together the two upgrades really change the driving experience.
Old 11-25-2019, 11:35 AM
Perimeter
Perimeter's Avatar
I noticed that CCM disc set prices took a $1000+ jump in the last few months, and Black Friday discounts?
Puck kits with blue high temp seal deals would be appreciated too, love your stuff!
Thank you
Perimeter is offline
Old 11-25-2019, 11:43 AM
RacingBrake
Former Vendor
2019 Black Friday Sales - Porsche Brake
Begins: 11/29/19 12:00 am
Ends: 12/2/19 11:59 pm
Carbon Ceramic Brakes (-7.5%)
991 - https://www.racingbrake.com/category-s/7570.htm
997 - https://www.racingbrake.com/category-s/7590.htm
996 - https://www.racingbrake.com/category-s/7571.htm
993 - https://www.racingbrake.com/category-s/7569.htm
Boxster (987/981/718) - https://www.racingbrake.com/category-s/7591.htm
Iron Rotor Kits (-10%)
https://www.racingbrake.com/searchre...Search=por-irk
Caliper Brake Kits (-15%)
https://www.racingbrake.com/searchre...Search=por-irp
NO NEED to enter a coupon code, once the item is added to the cart the discount will be automatically applied.
While supply lasts.
CCB rotor and kit limited to 3 orders per model.
Delivery: From 1 to 6 weeks depending on order contents and availability.
Order is served on first come first serve basis.
Perimeter (11-26-2019)
Old 11-26-2019, 02:53 AM
OldGuy
OldGuy's Avatar
Can you just replace rotors and pads and run stock calipers or must the whole system be changed?
OldGuy is offline
Old 11-26-2019, 09:51 AM
Perimeter
Perimeter's Avatar
Yes, rotors and pads are here, wonder if OEM PCCB pads would work?
What isn't so clear is the question are there XC-40 sintered pads for 991 GT3 application.
If you follow the brake guide it never shows any sintered pad for the CCMs on 991 GT3/RS cars but it is mentioned in the forum
Quick Reply: Complete RB CCM Brake Kit for 991 GT3
