.1 14 and 15 TTS. What problems?
These .1TTSes are coming off lease with low miles. What major issues have befallen them which would make you nervous outside CPO?
Received 1,543 Likes
Nothing - as far as an unabused purely stock TT/TTS goes.
Rocky Mountain High
No problems with my 2014. I rolled past 25,000 miles on the odometer today.
Received 2,020 Likes
Subscribed.
You must have a problem with some other part of the brake system killing your rotors. There’s no way manufacturing issues would result in you having two bad sets of PCCB rotors in a row without some other folks reporting the same problem.
The only other issue I had was in year three a very high pitched dog whistle type squeaking sound could be heard. That was diagnosed and repaired after dropping the engine and mostly dismantling the rear of the car as coming from the Cardan shaft. All performed under warranty. I have about 10K miles on the car now.
No issues. The PCCB issue mentioned above was just that some made a clicking sound, but it was not any type of performance issue. These cars have shown to be nearly bullet proof, and I would recommend them without hesitation!
On the other hand, there don’t seem to be any issues, discovered so far, that strike every 991 or the majority of 991s or even a whole bunch of 991s.
The vacuum valve issue is arguably, an exception, but it doesn’t seem to strike every, or even the majority of 991s.
Or, in other words, the 991 equivalent of RMS or IMS syndromes has yet to be discovered.
Air oil separator.....replaced on my '15 TT under warranty @ about 6K miles. I believe the total tab was about $1300.
Known issue. Engine "beeping" sound is the predictor.
______________________________
'15 Turbo
'15 Turbo
