Zunsport center grille, 991.1 Turbo...
#46
For those with a 991.2 Turbo without ACC, I have a brand new black Zunsports center grill that I ordered by “mistake” (according to Zunsports!). I would be willing to sell it for $75 plus shipping, if anyone is interested. Thanks!
Mark
Mark
#48
abiazis (02-24-2021)
#49
Installed mine today from www.zunsport.com
A 15% discount available if you use my Zunsport loyalty club membership number 1005 023052 - Andrew Biazis....easy install and quality exceeded my expectations - just a Phillips screwdriver, masking tape and a marker.....before installation vacuumed out the intake areas for dirt and leaves, and removed 4 small jagged rocks - photo below....Good protection/investment for around $300 for the set..........easy removable for cleaning too.....
abiazis (02-26-2021)
#52
I have ordered my grill set from Zunsport and in the middle of a dispute. Let's see how they handle this.
The order I received is for a vehicle with adaptive cruise control, I am well aware that my vehicle has no adaptive speed control, but this was the center grill that was sent to me.
#53
#54
Sending it back (according to the other member is almost just as expensive as ordering a new part)
#55
#56
Now you have me thinking to open the box I just got!
#57
#58
Update: The folks at Zunsport came through and will send the new part as I return the ACC ones. Good deal.
I also did the side grills today with my friend Ryan and they were a BREEZE to install. My only suggestion is to really line up the bottom grill first and install the clip correctly.
Once those "buggars" are in, they are borderline "impossible" to move or remove.
They look great and I'll show photos ASAP. I need to use an angle awl to pull and line them up better, but this was a 10 minute install.
Bottom line, these are good products and I can tell considerate R&D has been done to ensure the fit that they display. Good job Zunsport.
#59
Just installed mine today. Relatively easy install. The gripper clips were the hardest part for me. Overall very pleased with Zunsport black grills on 14 turbo S sapphire blue. I used the RL discount in the thread above. Delivery was actually pretty fast considering came from England. I would buy them again.
The following 2 users liked this post by radctt1:
CodyzWorld (03-06-2021),
MotorCityDriver (03-21-2021)
#60
Ok, thanks.
I have a two post lift in my garage and won't be tackling install until the spring, so it should make it a little bit easier, even if I don't end up removing the bumper cover.
If I can get in there with a brush and vacuum, I'll attempt the cleanup in that manner.
I think my body aches too much to go laying on the ground.
vrybad (03-19-2021)
