Launch Control question
Received 2,019 Likes
https://rennlist.com/forums/991-turb...out-tc-on.html
This is a Dragy test back to back with no cool down, etc. on a 64F day in a bone stock TTS. TC on vs TC off = zero difference. But the tires hooked well on no prep asphalt since it was 64F and the car was bone stock. Add power and colder temps, obviously traction will suffer........
RadarP3C (08-31-2021)
...unless your tuner has done something special with the button, which I do not believe is typical.
I can confirm this as I have a .2 steering wheel in my .1. The overboost button works during partial throttle as mentioned previously.
Originally Posted by CodyzWorld
Good tips. I'll try that.
So what procedure and set up do you do when you want to launch hard?
If tuned, all of the above + stickier tires.
CodyzWorld (09-01-2021)
I'm running 4S's in the rear, what should I lower the pressure to?
CodyzWorld (09-02-2021)
Lots of good advice on how to get the best launch and lower ET's - but I haven't used any of that advice. I run 38 psi all the time everywhere and I leave PDCC on. Maybe the only thing I do right is set individual mode to Sport+ but no aero. Consequently, I don't have good ET's. I run what I brung, as it were.
Full weight and tire pressures be damned!
93 octane
I spin a lot in 1st and 2nd even with traction control on, and I don't care. I'm not turning off traction control because I'm not a good enough driver to turn off driver safety measures. Some guys will have the skinniest dude drive their car to minimize vehicle weight when recording runs. Nobody drives my car but me and I'm 6'4" & 285lbs. Some guys do their runs with a tablespoon of gas in the tank - I keep the tank full by filling up every time I'm half empty.
93 octane
The following 4 users liked this post by Pb Pedis:
I always do my runs with at least a 1/2 tank of gas and a cooler with ice water on the passenger side floor.
My friends laugh at me but I like to know what the car can run worst-case scenario.
The following 2 users liked this post by vrybad:
Big Swole (09-02-2021),
"I spin a lot in 1st and 2nd even with traction control on, and I don't care. I'm not turning off traction control because I'm not a good enough driver to turn off driver safety measures. Some guys will have the skinniest dude drive their car to minimize vehicle weight when recording runs. Nobody drives my car but me and I'm 6'4" & 285lbs. Some guys do their runs with a tablespoon of gas in the tank - I keep the tank full by filling up every time I'm half empty."
LOL! I'll at least eat salad instead of a triple cheeseburger before track day! That's gotta be worth a tenth!
RadarP3C (09-02-2021)
93 octane
93 octane
135mph is great mph for 83F. Ride is making P O W A H
