Tracking the Turbo
#136
Thanks for the input everyone. Appreciate it.
#139
Keep it coming. Good posts, most don't track the turbo. Seems like a shame. Mine should be here in about 8 weeks, so love the tracking input!
#141
Be interesting to see how the Eagle turns out.
I thought the Trefeo R worked really well on the Turbo, huge improvement on dry track over the PZero, completely transformed the car.
Cheers
Cheers
#143
You bet. This month I have tracked Buttonwillow and Streets of Willow. POC has an event this weekend at Streets of Willow with a couple of Cabs signed up. The cab has built in roll hoops that will deploy in the event of a roll over and the car has a magnesium roof that is stronger than steel.
Cab tracks excellent. For me is my trainer before training in my Cup. The car is super stiff, feels just like a coupe. Only thing I would recommend is that you must get different tires than the P zero, mine pretty much melted after two track days and gave up a lot of grip real fast. I just got the Cup tires for this weekend, can't wait.
#144
And you missed a great run through the Malibu canyons a couple weeks ago--next time!
#145
I actually, had a track day opportunity the day before that run and was the only reason I missed. I hope to catch the next canyon run for sure.
#147
#148
As I will use my Turbos S for a vacation trip next week to northern Norway I need to put on my regular wheels. Weather can be rather nasty up there with low temperatures so P Zeros are preferred before Cup 2's.
This gives me a good opportunity to change brake fluid while the wheels are off anyway. I my opinion stock fluid delivered with the car from new does not handle high temps good, so I will now use Castrol React. I have good experience with this from my GT4.
With right tools it's a straightforward job.
Some homemade stuff that is handy.
Inspection of pads and rotors, all is fine.
Old ****
Which is nicer?
Left front that has take most punishment, not too bad after two trackdays. Will switch side when I put back on.
Old ****
Which is nicer?
#149
If you are still looking, I am using the Ferodo DS1.11. I've gone through 2 sets of OEM and on my second set of Ferodos. I do about 14-16 track days a year and found the initial bite is better and pedal effort is reduced versus stock pads on iron rotors. They also last about 8 track days (I change them at 4mm) in the front, double track days (16) at the rear. Most days are at Sebring, some at VIR, WGI and Daytona. I know I change them early, so you may get more time out of them. That's on a GT3 which are the same brakes but a bit lighter car, with a less intrusive PTV. So depending on driving style the Turbo rears might wear faster than mine.
#150
So how far have you guys on this 991 Turbo forum modified your TT for the track?
Contrary to any common sense and wisdom, it looks like I am going a bit too deep into modifications on a heavy 4WD for time attack and hillclimb racing, but the car seems to be super competitive..!
Anyone else here have gone that slippery slope ? Pictures, mod lists anything would be interesting to see.
