Throttle response delay on 6MT
#106
not sure that is the reason in my opinion but I may try to release the clutch faster. I drive the same though so it should not be the reason. so today it got worse. not just a choking when downshifting from 3rd to 2nd, braking and then throttling back up. that did happen again today but it also just completely had ZERO throttle in second and then again downshifting to 1st. Zero throttle. Gotta take it in. Very odd. Only at a little over 3,000 miles.
#107
Any word on the sprint booster?? Month later and not a word..
#110
#111
Maybe this was put in place to save the clutch/flywheel.
#112
Hey sorry guys, been MIA. So Dr. G was kind enough to send me the sprint booster, no improvement. At this point I’m thinking it is the no lift shift that’s causing this issue. The ecu doesn’t allow for a manual throttle blip unless the clutch is fully depressed and even then, it was to be a very and deliberate action. I owned several bmws and Porsches, mostly M and GT cars and have never had a hesitation like this with the throttle. I think the car thinks we’ll be shifting into the next gear and it’ll will be while the throttle pedal is being depressed for the no lift shift and so it’s not allowing the engine throttle to rise above where it needs to be. If you leave auto blip on, you should notice that the ecu is constantly intervening with the throttle to make up shifts and down shifts perfectly smooth. While it’s nice to have that perfect shift every time, I honestly don’t see this platform allowing for crisp heel toeing. If there is a way to code out the no lift shift, I’d be ready to try it.
#113
Is this the behavior in 991.2 GT3 as well?
#115
Is what’s on this video what you guys are talking about?
Watch it from 5:17
Watch it from 5:17
#116
Luckily I have not experiences this at all.. Just got mine 2 weeks ago.
#119
Just noticed it for the first time a couple weeks ago. It doesn't happen open and it always seems to be at a low RPM only under 20 MPH or so.
#120
Watch it from 5:17
https://youtu.be/hHBvcNUF-tk
Watch it from 5:17
