3RS and PPF
#31
I usually only PPF the front end on Porsches but the cutouts behind the front fenders leave the sides rather vulnerable. Leaning towards full body PPF over top of the factory decals.
XPEL (06-07-2023)
#32
My experience with the modern ceramic coated PPF is that decals won't stick very well to it. So keep that in mind if you want to pull decals and then install new ones. The decals will go on, but the slightest touch and pull them off, like when you go to wash your car or as in my case dry it off. If you want a decal look, it may be safer to have them under the PPF or find a PPF that doesn't have ceramic coating in it.
Just my $0.02 hope it helps someone.
#33
Basic Sponsor
-Chris
XPEL Inc.
Support@XPEL.com Phone: (210) 678-3700
XPEL.com "Like" us on Facebook Follow us on Instagram
XPEL Inc.
#34
I ordered my set in red from my Porsche dealer. Attached a pic of the backside, maybe it helps some of you to know that the original ones are made using Oracal vinyl. If you google Oracal 970 it will give you all the sample colors and there are a few reds to choose from. Should be easier now to find the correct color. Maybe they use the same vinyl for the other colors as well.
SuperDarius (01-18-2024)
#35
#36
Former Vendor
Brian Himmelman (01-17-2024)
#37
before I think the right one is 031 red….but maybe i’m wrong.
#38
Would need to order a sample to compare … up close the Pyro red has slight metallic … I have Tribute red front and rear from AHA Graphics on here which I won’t be able to tell how close til they are removed from plastic cover and compared but will report back
#39
not big problems…but just to have the right ones when the car will be here.
#40
Brian,I ordered a sample of 368M ,this morning I was at my ppf guy and looking at the palette of Oracal i think is probabily more right the 970 M368 than the 631 M031 i have at home…
Will be here end next week,in the meantime if you can post some pics that report the colour of the Pyro decals in the more realistic way,would be great.
#41
also have these Weissach RS from Suncoast as not available at build …. Need to decide soon which look to go with, leave factory or Tribute (Canada colors) or WS decal POLLING all opinions valued? thanks
#43
as at my PPF shop yesterday and the AHA red is much less dark than OEM see pic … I too will get a sample but feel like that 368M could be it
i will paint the side plates of the wing white and then put RS decals…good also the Weissach decals,but with white on the back will looks better from my view.
have you noticed difference after ppf on the sides decals?now are no more matte…how it looks?
Again one month I hope…can’t wait.
#44
great,your car has same specs as mine!
will need to put a matte piece clear PPF like factory over the area in front of rear wheels as it will get peppered
#45
yes matte side decals are no gloss but doesn’t look bad or change the color … I much prefer above PPF and matte look so have ordered replacement decals from dealer and will apply mirror on top of PPF and replace as they get beat up … the original will be protected safe under the PPF
my fear doing ppf is the risk that they can cut the paint with that cutter ,the ppf guy tell he doesn’t use it and he doesn’t take off parts of the car…,but,but…I tell him to make the car at home,in way I can make some random inspection to look what are they doing…
Usually on my former 911,i make only ceramic coat,but this time there are too much parts exposed to little stones,ecc…so I think there is no other way to protect them.
