3RS and PPF
3RS and PPF
For those of you who have taken delivery and wrapped your cars in PPF, did your installer remove trim/aero pieces around the perimeter of the car (e.g., the vertical slats behind the wheels and the front lip) in order to make the install easier/cleaner? If these pieces were removed, any insights on how easily they come off? And how did you deal with your decals?
My installer swung by today to look at the car. Here are a couple observations:
- There is factory PPF directly behind each of the four wheels and on the lower section of the rear quarter (in front of the rear wheels). These pieces leave something to be desired in terms of cleanliness of install and coverage - the ones behind the wheels still leave quite a bit of vulnerable paint exposed.
- The PPF on the rear quarter in front of the rear wheels has the decal placed on top of it. If you want to remove this piece to wrap the full quarter, the decal is coming off too. If you wrap over it, you're going to end up with visible 'transitions' at the factory wrap and then again at the decal.
The following 4 users liked this post by Tik:
Great feed back & info. Plz keep us in the loop with pics and suggestions. Mine arrives July.
Matt
Matt
My PPF installer did not remove trim/aero pieces at my request. I was warned by the dealer if something went wrong in putting them back on it would not be covered by warranty. And apparently they have seen that happen a lot.
My installer removed all the factory stonechip foil before putting the full ppf on. My decals are now in the bin unfortunately, because Porsche puts them on top op the stonechip foil.
So my recommendation for the people still waiting for their car that are going to do a full PPF, ask Porsche to not install the gt3rs striping and just deliver those stickers with the car !
I now have a "naked" car with full ppf, and I'm still deciding what to do. I'd love to put new original red gt3rs striping back on. But I'm also doing low key livery with my company name and or logo's. And I want that to be the same material and color for a uniform look. Unfortunately Porsche won't or can't say what brand, type and color of stickers they use. So unfortunately I might have to go without the original striping, unless someone here has the info on the red factory gt3rs striping stickers ?
Curious what others have done here.
Received 1,015 Likes
I ordered up an extra set, the sides run about $700, the extended run $1500.
Remove when PPF and apply new set.
User 81423 (04-26-2023)
This wrap shop in Germany managed to recreate the graphics in red. Not sure if it's the exact same red but it looks really good:
https://www.youtube.com/shorts/_uAhoOmSh3Y
Suncoast has the decals listed, though they are coming from Germany and will take a few weeks:
https://www.suncoastparts.com/produc...rsstripes.html
My installer has removed the stripes to apply film but I'm in a bit of an easier situation as my decals are matte black. Factory decals are a few weeks out but if we can get the vector files he can print them and reapply over the film.
The following 2 users liked this post by Tik:
bccars (04-27-2023),
Brian Himmelman (01-15-2024)
Thanks for the info as I will be facing the same issue in 2 weeks with my red decals. Will check with my dealer how long will it take to deliver the side decals and will order a set too if they can supply quickly, otherwise will need to search for a different solution…
Regarding the red decals, if anyone gets to know who manufactures them and what is the color code, I would highly appreciate that info as I want to wrap the wing end plates in the same color.
bccars (04-27-2023)
Doing so creates visible transitions (air gaps) at the edges of the factory PPF and at the decal. It also changes the decals appearance to glossy (or whatever the nature of your PPF is). All depends on what you're ok with.
bccars (04-27-2023)
Not LOL. First of all, I'm in Europe, so maybe our situation is different. Second, it is my dealer that proposed that to me. They then just put the stickers with the car, together with all the other bits that have to be installed at the dealer. The cars are not 100% assembled when they arrive at the dealer.
LOL, you can’t ask Porsche to not install anything, it violates multiple laws. One of which is actually import customs, if it’s not on the build sheet they have to remove it or refund you. So, basically can’t ask them to leave them in the car, they need to be attached to the car or it’s an import violation.
User 81423 (04-30-2023)
I had the parts department look into getting me a matte black set and they said it wasn't available in the US yet. I decided to order them from Suncoast Parts however, they emailed me this morning saying it won't ship until June 8th. I have a feeling theirs is printed by a local vendor since it's a separate listing from all the other colors.
Anyway, this timeline isn't ideal for me so the search continues..
