992 GT3 Impressions (Manifold)
#541
I would say pick any track of your choice and look at each car within a 3 car radius both up and down of the 992 GT3 in lap times and that is the competition. Of those 3 +/- which have better low speed suspension quality? Price can be looked at in so many ways I’m not really even factoring it in. Some of the cars that sell for a much higher MSRP of the GT3 could be had on the used market for lower price than a used GT3 and market value is all over the place by region and etc.
Manifold (01-25-2024)
#542
Comparing MSRP to a different cars current, used pricing is a tough ask
#543
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,860 Likes
Everyone is entitled to their opinion, but worth pointing out that I have not seen a single other person claim the 991.2 3RS has a better suspension than a 992 GT3. I'm not speaking to how visceral they are or feel or any other attributes. But how can you not feel the far superior double wishbone as better?
I've had the Touring and 991 2RS back to back on the track 3 times and the difference is very noticeable.
The next 2RS with a double wishbone is going to be insane
Driven hard on the road, 992 GT3 turns in and loads up better than the 991.1 GT3. On the track, the difference is less.
I'm not seeing any technical reason why double wishbones are going to ultimately deliver substantially more max grip (else all performance cars would use them).
#544
#546
Because of the cost/revenue figures (costs less to use struts and customers of non-GT cars don’t demand them, yet…).
I guess it’s possible that they’ll see wider use in 992.2. They were always going to install race parts in GT products first.
PTS (01-25-2024)
#547
#548
At the end of the day Porsche is still a mass produce car company and thus will do as little as they need to, which maximizes profits. Decisions are based on $$, not what's best for performance.
In contrast, you take something that is specialized and low volume like Gordon Murray's T.33 & T.50 and you better believe they will do what is best for performance, but that is also baked in to the cost.
AlexCeres (02-28-2024)
#549
Maybe next one will get it.
Miata is the most tracked/raced car in the world - great that it uses proper suspension at that price. They prioritize handling and light weight beyond all.
#550
You don't see any technical reason why a double wishbone front end is superior for grip over a mcpherson strut system? Come on.
#551
#552
Grip is ultimately down to the tires and keeping the contact patch connected to the pavement. I understand that double wishbones help maintain the camber as the suspension moves, but with stiff enough springs and active damping, the car doesn't roll much anyway, and my understanding is that struts and multi-link can be designed to produce similar grip to double wishbones. I'm not an expert on any of this, just going by what I've read.
There are too many arm chair quarterbacks/writers, others don’t drive fast enough, others maybe too fast, so the dynamics change way to much, so take all “read” items with a grain of salt and only way to confirm results are to try it yourself and make your own opinion. You and I can drive exact same car, but I’d bet 2 totally different opinions.
In my opinion, this is the best suspension I have ever driven on a track, hands down.
Mr Mojo Risin (01-27-2024)
#553
If there is an optimum amount of camber when loaded in a corner, you basically need to have that amount at rest on a strut car (so you have very little tread on the ground in a straight line for braking). Since wishbones gain camber as they load, you can have less static camber for better braking and still have optimum camber in corners.
And then there is the way these things behave with curbing and uneven surfaces - wishbones handle that far better.
#554
LOL, that’s is sooooooo true, going what “I’ve” read. On my GT4 & .2 GT3, I dealt with uneven tire wear, I went with what I read and guess what, it was wrong!!!! In hindsight, for the GT4, anyone tracking and with pace should immediately switch to 3 ways, I wasted sooooo much time and $$$ doing this and that. I was told by a semi pro driver that at Buttonwillow, a stock 992 GT3 should get down to a 1:50/1:51, and I did a 1:53, I did like 7 sessions and at end of the day, the tire wear was so even across the tires, I was totally blown away. And btw, just like all the people writing about and bashing the CUP2, weak sidewalls etc, crappy tire, this CUP2 with tread rating of 220 was incredible. This is true live experience on the road, not read, not heard, but experience on the track. Can anyone explain how my tire wear was sooooo even with a totally stock 992 GT3? Only mod was -2.5 all around, I’ll tell you, it’s the suspension, plain and simple. I didn’t magically change my driving style, nothing diff besides the car.
#555
The bigger issue with struts is the amount of toe change. Yes to a degree camber, but toe is what dictates stability and with struts the toe changes are big compared to wishbones.
Manifold (01-26-2024)
