Tire Pressure for Street
I recently saw questions about tire pressure for the track and was curious what people are running for the street? I have Cup 2 tires.
When I was looking it was interesting the door jam did not match what is in the manual. They are pretty close, but different.
Door 32/35 Manual 31/34.
TPMS display seems to be a few pounds higher compared to when I use my pressure gauge (I verified with 2 gauges). The MyPorsche app is +2 +3 lbs higher than the actual pressure.
The Performance pressures give better handling and ride quality, but should not be used over 290kph (around 180mph).
When I use a good separate digital pressure gauge, it shows 2psi higher than what the dashboard says…
New owner and I recently adjusted from whatever high pressure the dealer set the car at, to 28/31 based on the advice of the forum. It’s as described; a night and day difference.
The following 6 users liked this post by jonbek:
catdog2 (10-08-2023),
Diablo Dude (10-08-2023),
dixonk (10-15-2023),
GrantG (10-07-2023),
GTS440 (10-08-2023),
and 1 others liked this post.
absolutely, I set to my motion pro gauge, and completely disregarded what the dash said. 🥂
