Which Hi Flow Cats don’t throw a CEL?
Interesting comments...
I have tested 2 different Soul 200 cell sport cat versions (one with HJS inserts and the other an unknown catalytic insert), both with and without spacers. Every version threw O2 sensor CELs.
I have gotten very handy clearing O2 sensor CEL codes with my code reader . No biggy!
Received 2,537 Likes
One of the qualities that you want to pay attention to when purchasing any aftermarket Catalytic Converter is how much of the precious metal coatings they actually use. A thin coat and a converter that didn't set any codes when new, over time, will begin to.
One may agree or not with California's Law that prohibits the sale or delivery of any aftermarket automotive converter to any California address. To sell one in California the manufacturer would need to get what is called an "Executive Order" from the ARB. No Executive Order and you're simply not doing Catalytic Converter business in California. I bring this up because the reason California become such a PIA about this was because if a car failed it's smog test, the owner would slap on a new, typically budget level, aftermarket converter. Miraculously the car would then pass the emissions test. But within about six months to a year or so these Catalytic Converters would be worn out. That's why the state banned their sale. If a Catalytic Converter, either an Aftermarket or an Original Porsche Converter even begins to wear out (Federal Emissions Law), the programing of the computer not only will, it's actually required, to generate a Fault Code and turn the Check Engine Light on.
Now, if you have to use Extensions on the O2 Sensor that is downstream from the Catalytic Converter, to prevent a Check Engine Light, you're gaming the system. What you're doing is to stick this O2 Sensor in a back closet, behind the dirty laundry . . . . . and then asking it what the exhaust mixture is doing.
If a Catalytic Converter is working, the O2 Sensor after the Catalytic Converter will report very little change in the exhaust over fairly short periods of time. If a Catalytic Converter fails, the O2 Sensor that is after the converter will appear to mimic the O2 Sensor that is in front of the Catalytic Converter. This is because nothing was done to the exhaust gas when it passed through the Catalytic Converter. In a way, the two O2 Sensors are the "Before" and the "After" pictures. So what the extensions are doing is thy physically prevent the After Converter O2 Sensor from seeing the exhaust gas oscillations that would indicate a failed Catalytic Converter. Thus setting a Code or Codes and to turn the Check Engine Light on.
eclou (01-03-2024)
Aren't HJS 200 CATs pretty much the same?. I guess i don't understand how a vendor X is claiming their CATs is different from vendor Y. Maybe i am wrong and HJS makes different CATs for same vehicle per vendor The randomness to the CEL is probably the most annoying thing about upgrading CATs in the car. Prior to tune to remove CEL it would come up one day i clear the CEL and returns about 30 mins later other times CEL is gone for a week or more. Initially thought it was not allowing CATs to warm up before driving hard but that was not the case because sometimes i would purposely drive slow and within 15 min boom another CEL
I think someone here mentioned the CEL is consistent on MY22+ Cars. Curious if any member have MY22+ , 200 CEL CATs or less and have no CEL plus have had the car for a long time.
I had soul performance HJS 200 sell catalytic converter and I got a check engine light I contacted soul and they sent me a new set of catalytic converters now I do not have a check engine light knock on wood as yet but I only get to drive it 40 miles so far , but I’ll like to say customer service is extremely great !
