DIY A/C bracket modification for ease of belt installing
Old 12-13-2012, 05:12 AM
ttAmerica RoadsterAWD
ttAmerica RoadsterAWD's Avatar
Default DIY A/C bracket modification for ease of belt installing
-Problem: It seems Porsche NA engineered tolerances too tight to allow easy changing of fan belt on some of the 993TT. As a result, one cannot easily remove and replace fan belts due to clearance issues between the innermost pulley and the AC bracket found on the right side of the pulley at exactly 3 o'clock
-Solution: Hack-saw off this AC bracket corner and clean up with a metal file
First photo: This is the problem: Belt too large to clear pulley; to the left of that 17mm nut
Second photo: This is the tool you will need. Purchased at Lowe's
Third photo: Job about 1/3 done. See slice into bulky bracket; remove 17mm nut to allow improved access
Fourth photo: File used to clean amputated part
Now belt goes in the honest way without stress. Note bracket is still solid and does not seem to compromise integrity
ttAmerica RoadsterAWD is offline
Old 12-13-2012, 09:31 AM
911PERVY
911PERVY's Avatar
Good job! And a tad cheaper than the modified bracket from Porsche at $1500
911PERVY is offline
Old 12-13-2012, 11:28 AM
Quadcammer
Quadcammer's Avatar
Received 1,371 Likes on 794 Posts
well done, will do this the next time I need to do belts
Quadcammer is offline
Quick Reply: DIY A/C bracket modification for ease of belt installing
