993 Forum 1995-1998
Airbox cover plug
Old 01-21-2018, 06:39 AM
heinzbush
heinzbush's Avatar
Default Airbox cover plug
Hi All,
I installed the engine sound package airbox cover today. I saw that there is an additional hole, which was covered on the "old one" with a simple rubber plug.
Here is a picture from another thread that discussed the topic, but didnt come to a conclusion:
Question:
I understand for manual transmission cars, it is important to connect the suction from the gearbox. However for Tiptronics, I assume I can simply leave the plug removed to allow more air to get in.
Correct?
Thanks,
Old 01-21-2018, 08:33 AM
Railmaster.
Railmaster.'s Avatar
It sucks air from the clutch and som people recomend that You disconnect it in otder to prevent Your engine from inhaling clutch dust!
Mine is still connected, I trust the German engineers!
Old 01-21-2018, 08:35 AM
heinzbush
heinzbush's Avatar
Hi,
yes, but on Tiptronic cars, my understanding is, there is nothing connected, you simply have the rubber in the hole!
Old 01-21-2018, 09:55 AM
jrmdir
jrmdir's Avatar
+1 !! My Tip has the plug in place. Can't imagine the factory would design the air box to be so close to the margin on air-flow that another small (unsightly if not covered, IMO) open hole could ever provide any induction benefits.
And if I had a 6-speed, I think I'd trust the air filter to catch any stray clutch dust. - instead of letting more of it accumulate in the trans.
Old 01-21-2018, 10:18 AM
AOW162435
Seared
AOW162435's Avatar
Swap the plug from the old cover to the new. I think it looks unfinished otherwise.
Andreas
Old 01-21-2018, 10:27 AM
P-daddy
P-daddy's Avatar
Leaving it uncapped won’t make much of a difference in terms of drawing in more air on a stock motor. I’d swap the plug as suggested or buy a new one.
Old 01-21-2018, 06:24 PM
User 122821
User 122821's Avatar
I removed the transmission clutch vent from the airbox and purchased the plug from Sunset. My air filter last so much longer now. My understanding it is just there for meeting air quality regulations in some countries.
Old 01-21-2018, 08:27 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Think of the tens of thousands of manual transmission 911's that didn't have the clutch vent tube. Ever heard of a clutch failing because of accumulated clutch dust? They usually fail because of a worn disc, bad throw-out bearing or a seal going bad. When clean air means everything to your engine, who would want to suck clutch dust into it?
Old 01-21-2018, 09:41 PM
jrmdir
jrmdir's Avatar
Appears to be a good bit of prior discussion on this topic......https://rennlist.com/forums/993-foru...he-intake.html
Old 01-22-2018, 05:52 PM
Endoman
Endoman's Avatar
Pulled my clutch vent pipe out when I did the r/h plug bank and left it off as many have done. It's the only Porsche that uses it. Outlet on clutch housing covered with wire mesh and airbox bung fitted along with with techtronic engine tin. Flexy pipe had disintegrated many moons ago so probably non funtional for ages.
Quick Reply: Airbox cover plug
