Oil change
Oil change
When changing the oil, how important is it to drain the crankcase oil? It seems last time I changed my oil less than a 1/2 quart came out of the crankcase....also, just recently I forgot to drain the crankcase oil, but changed everything else out.......should I re-do my oil change, just drain the crankcase or leave it alone?
No studies have been done on this, however, it is so easy to do and offers the opportunity to inspect engine debris at the drain plug, why not do it?
RL Technical Advisor
JMHO, but one REALLY needs to drain both the engine & the tank for a proper oil change.
If you've already started the engine, I would not bother to re-do it, however I would cut the next oil change interval in half.
I hope you changed both filters.
What, no.
Your car is fine, if the engine was run before the chqnge, there isnt more than like 1.5qt in the case.
Reduce your interval a bit, sure.. redo is a total waste of time and money
Agree - just cut the interval. Oil changes do a few things: get dirt out of the engine, get worn out oil out and replaced with fresh oil, get metal and other drebis out, get water out. So you just removed maybe 80-90%. So I would just cut the interval down. Oil changes aren’t always even 100% changed anyway. There is always old oil left somewhere in the engine, oil passages, oil coolers and lines, etc.
Thanks guys.......I’ll just cut the interval in half...I agree with Murphyslaw1978, I believe I got 80-90% of the old oil out.....should be ok, unless someone says different....
If we are talking contaminants that change and break down the additives and can change the chemical formulation of the oil, then that that level of wear cannot be fixed no matter how clean we make the oil unless we put back those missing additives.
There are some that say that even the base stock oil can break down under intense temperature and pressure, but that’s usually under race conditions, not on the street.
I just changed mine yesterday. Entire process really doesn't take that long. However, adding the last four quarts of oil takes a lot of patience. I feel so much better about myself now that it is done.
Top quality oils contain Group IV or Group V base stocks and those hold up far better than the oils that use Group III or less.
