FS: 993 Fister Mufflers Stage 2
Will these fit/work on both C2 and C4S?
I am interested in either case.
Not affiliated...but I have a set of these Stage 2 mufflers, and they are sound incredible...not too loud, not too quite...just right. Oh, and no droning when you're just putting around like I do!
They are great, I've heard Fisters and had them on previous 993 and 997 as well, i thought they would fit on my 964 which as a 993 engine and exhaust but of course the rear bumper on 964 is very narrow compared to 993 so they will never fit.
I’ve used FD modded 993 mufflers in the past, amazing product and Darin is a good friend of mine. But the ones pictured here seem to have some Very substandard welding on almost every part that has been removed to get into the can, take a close look at the beads, sloppy does not even begin to describe them. Just pointing out a pretty glaring issue...
I’m just pointing out the obvious man, if you don’t recognize it then you have no clue about welding. Which isn’t surprising since you thought these would fit a 964 lol.
lol, well, you got me there! i agree, i definitely have no idea about welding- fitting the 964 part, i sent videos and pics and talked to Darin, the 964 i have has a 993 engine and exhaust and he told me that they should fit- obvoiusly they are so much larger they wont' even fit inside the bumper. I have no problem with you man- If you and i ever met we'd probably get along, just get off my case a little bit, thanks.
I have posted some pictures below: What you are seeing in the pic is the factory weld under our weld. We cut just above the factory weld and then TIG weld them back together (with stainless) above the factory weld. We have no issues with any of the work we do woth our modifications. If there ever is ever an issue we back our work 100% (including these welds) with a lifetime warranty.
