993 Forum 1995-1998
Sponsored by: DashLynx
Oil level - leave it alone?
Old 02-26-2019, 06:26 PM
  #31
mike cap
mike cap's Avatar
Originally Posted by rk-d
Ugh, whatever dude.
When I say micromanage I'm referring to feeling like I'm micro-managing the shop and how they do an oil change.
And yes, when you pay good money for a service, having to go behind someone else's work is a PITA. Doesn't mean I don't appreciate the advice from the board.
Thank you to everyone else for the constructive thoughts. It's a learning process owning a car like this, especially when there aren't tons of shops capable of working on them.
The combination of the 993 idiosyncrasies and RL advice can make you nuts. Your oil level is fine don’t sweat it. My shop puts 10.5 qts in the 993 and 9.0 in the 997.2. These amounts seem to work best and may require a small OCD top up when checked hot. You’ve only begun to experience the 993’s essential weirdness my friend - ballast resistors, door pocket reinforcement kits, DME relays, immobilizer glitches, door lock actuator failures.......
Old 02-26-2019, 06:40 PM
  #32
kary993
kary993's Avatar
I would agree with RL making people nuts!!! These 993's are very durable and worrying about the oil level being full (not over filling) is not worth the time. whoever does your oil change should provide you with a quart of half a quart when you leave. It is so easy to get the oil level right where you prefer doing it that way. Discussions of warming up cars for periods of time etc...just begins to be crazy. Fill the car with oil, turn the car on and drive it smoothly at first...then let it rip once the thermostat value has opened and warmed up...everyone knows that part ..... I hope!
Old 02-26-2019, 06:41 PM
  #33
Twilightblue28A
Twilightblue28A's Avatar
It takes a lot of ***** to make that comment considering your 1,000 posts about the heating system in your car. And the fact that you repeat yourself endlessly AND never take anyone’s advice. Wow.
Mike,
Your comments are at best disingenuous and embellished.
Old 02-26-2019, 06:57 PM
  #34
cgfen
cgfen's Avatar
Originally Posted by Twilightblue28A
Rk-d,
. You were given expert advice and choose to ignore the advice provided.
LOL
I don't see any experts on this thread, but I do see some that think they are....................
All posters merely wrote their opinions, some more fully informed with facts than others.
Cheers
Craig
Old 02-26-2019, 07:08 PM
  #35
abiazis
abiazis's Avatar
Originally Posted by cgfen
LOL
Cheers
Craig
Time to go to the manual..............
Old 02-26-2019, 07:44 PM
  #36
pp000830
pp000830's Avatar
Received 1,456 Likes on 1,027 Posts
Rk-d,
You do not have to do anything if you feel that it's a pain in the *** and micromanaged. Leave your oil level where it was before you consulted our advice. You were given expert advice and choose to ignore the advice provided.
You make no sense.
Twilightblue, Makin' friends and influencing people I see.
Old 02-27-2019, 04:36 AM
  #37
Railmaster.
Railmaster.'s Avatar
Peace brothers!
Old 02-27-2019, 10:51 AM
  #38
mpruden
mpruden's Avatar
Originally Posted by Gbos1
Temp should sit half way when oil is up to Temp..... let it idle till it does. Takes a good while for all 12 quarts to heat up! Especially if you are in a colder climate. So as long as you are driving the oil level needle should be pegged at the bottom while driving then rise at idle at a light or stop sign. Overfill will burn off but SAI problems may be in your future if you continue overfilling.
While this info isn't inappropriate for purposes of verifying oil level, it's not accurate based on the the manual.
1) The 993 oil thermostat opens at 181F.
2) The first single line on the oil temp gauge is 194F.
3) Assuming sufficient airflow to the oil cooler, the car is "up to Temp" once it hits 181F, before the first line, and certainly before "half way."
4) 9:00 on the gauge is probably 221F, 40F beyond when the car starts to cool itself. In fact, if it gets much hotter than 9:00, a (properly working) low speed oil cooler fan will kick on to force the temp back down.
Just trying to keep Rennlist accurate. Back to your regularly scheduled program.
Old 02-27-2019, 11:32 AM
  #39
TMc993
TMc993's Avatar
Even though I sold my 993 and moved to a Cayman a couple of years ago, I still wander back over to the 993 board every now and then just to see what's going on. I had to grin when I came across an active thread on measuring oil level, yet I read every post just to see if anything has changed. It hasn't of course and the 993 crowd still has the best technical board on RL. Guess I'll wander back over to the Cayman board and see how the door decal poll is going.
Old 03-01-2019, 06:46 PM
  #40
Gbos1
Gbos1's Avatar
Quick Reply: Oil level - leave it alone?
