Radio reception
Radio reception
Hi again,
The reception on my stock radio is terrible. When I turn on my waze app on my phone, which I power from the cigarette lighter, the reception gets worse. Do I have a loose wire somewhere or is it something else. Please HELP.
Thanks,
Mitch
Thanks,
Mitch
Try to remove the 5V charge adapter from your cigarette lighter. It might be causing a lot of radio noise, especially when the phone needs a lot of current.
The windshield FM antenna has a antenna amplifier, this needs to have +12V feed from the head unit. The antenna amp power feed wire is a thin black or white wire bundled with the antenna coax, and needs to be connected to the proper output on the head unit.
Cheers,
Tore
Cheers,
Tore
