993 Forum 1995-1998
Sponsored by: DashLynx
Sunroof problem.
Old 05-16-2019, 02:08 PM
gmorat
gmorat's Avatar
Default Sunroof problem.
Hey
So my sunroof opens on the press of the button as expected but to close it you have to press the button twice, once does nothing and so you press again and it close. Motors sound normal. No groans etc.
Thoughts?
G
Old 05-16-2019, 02:35 PM
pp000830
pp000830's Avatar
Received 1,453 Likes on 1,024 Posts
Just some thoughts:
It could be the cable crimp on the end of one of the side drive cables beginning to fail to cause the roof to twist slightly and jamb as the two sides don't move exactly in parallel. Have someone cycle the roof as you observe its movement. Any out of sync movement left to right will be readily apparent.
Rocker switch in the console could be on its way out.
Or an end of travel switch in the motor housing.
An end of travel switch may be internal to the gearbox and if present it is probably a microswitch that has old grease on it causing it to stick. I looked at the drawings and to me, it was unclear as to the presence of the switch. If present a little electric motor cleaner spray will probably resolve a stuck switch. Others may chime in here and help,
Looked at the wiring diagram and saw an electrical device option 439 called a roof catch related to the sunroof, it also is unclear as to how it functions but it may also have a switch or is the end of travel switch.
Gently open the 20-year-old zipper in the headliner and you should be able to very quickly identify any switches that are present. I would go the extra step and rub a rag with a few drops of silicone lube on the zipper before opening it reducing friction on the zipper's teeth in the hope of not damaging it when zippering.
Andy
Old 05-16-2019, 03:25 PM
nine9six
nine9six's Avatar
It sounds to me more like a switch issue...
When you open the sunroof, put your fingers on it so you can feel it as it opens without adding any helping motion or pressure.
Now, when you press the close button one time, see if you can detect any slight movement in one direction or another. If you feel any movement in either direction, then you will more than likely be dealing with a misadjusted microswitch, which will require a slight adjustment, in order for the sunroof to operate normally.
Just my guess...
Old 05-16-2019, 11:08 PM
Gbos1
Gbos1's Avatar
Switch? They do go bad
Old 05-17-2019, 09:42 AM
levtron
levtron's Avatar
+1 for switch. Had the same issue. I had an extra switch that was used for a garage remote. Swapped out the guts, and all works great.
Your mileage may vary...
Old 05-17-2019, 11:27 PM
gmorat
gmorat's Avatar
Good advice, I'll dig in and see what's up and report back when I know anything.
G
Old 05-27-2019, 07:12 PM
gmorat
gmorat's Avatar
Bad switch. Replaced and it works as intended each and every time.
Old 05-27-2019, 08:45 PM
pp000830
pp000830's Avatar
Congratz! Glad it sorted out easily.
Old 06-06-2020, 07:26 AM
Magdaddy
Magdaddy's Avatar
Issue appeared yesterday for me, opens normally...won’t close. Initially a few cycles of the close end of the switch would get it working, now it takes holding the button and giving an ever so slight pull on the roof to close.
I’ll check the switch first, thanks for the details gentlemen.
Old 06-06-2020, 12:42 PM
The Eagle
The Eagle's Avatar
Have a look at this: link
~ The Eagle ~
______________________
'96 Polar Silver/Black C4S, manual, litronics, LED's in the positioning lights, alu/leather shifter & handbrake, silver face gauges with alu rings, hardback sport seats, leather interior, motor sound airbox, stainless door sills, valve caps Porsche crested brushed alloy, front protection bar, with split rear grill and layered with Meguiar's NXT Tech Wax
'92 Carrera 2 (Sold) '89 Carrera 3.2 (Sold)
Old 06-06-2020, 12:57 PM
Edward
Addicted Specialist
Edward's Avatar
Magdaddy,
When mine was acting up, intermittent and such, I took it apart, cleaned the obviously carbonized/corroded bits, and the switch works as good as new. It is a straightforward 10 minute surgery.
Edward
Old 06-06-2020, 09:45 PM
Magdaddy
Magdaddy's Avatar
~ The Eagle ~
Originally Posted by Edward
Magdaddy,
Edward
thank you gentleman...perhaps tomorrow afternoon I’ll get to this.
Quick Reply: Sunroof problem.
