Non synthetic motor oil
97 993 C4S
I'm reaching out for a little peace of mind , over the winter had some work done at my local indie , complete tune-up , clutch , wires etc...also a couple of seals one of which was the front crankshaft seal , soon realized that it was leaking and the indie at their expense changed the seal and also did an oil change and added a mineral non synthetic oil , their reasoning being a non synthetic oil is beneficial to seals & gaskets & often stops small oil leaks , as I've owned the car since new and have only used synthetic oil should I be concern. Many many oil threads and I've read them all & as far as I can see no one uses anything but synthetic...I've just purchased mobil1 Vtwin 20w50 but wondering if I'm overreacting..here is the oil installed.[img]cidF816B1D-145D-4D5E-9119-E7A3FB16AED8
Received 5,391 Likes
I'm not a believer in self correcting magic fluids for leaks.
Your selection of the V-Twin is an excellent one.
Just do an oil change in a few hundred miles.
That old "advice" about synthetic causing leaks is due to the synth flowing better and seeping past brittle old seals ( sometimes cracked) more than conventional oil.That and the cleaning by the oil can remove varnish , build up on seals and poof you get OMG, synthetic caused a leak. But seeing how you have been using synth , I would think you would not have any build up from conventional oil use.
For a street car, I would just go back to synth with next oil change.
Synthetic oils in most cases are not made from a synthetic base they are just regular oil refined to a higher degree removing more components that the additive package needs to keep in solution to avoid sludge. The big advantage is that at cold-start where synthetic oil need not be as warm as regular multigrade oil to get into a viscosity range where its lubricating ability is effective. This is, in my opinion, the most important feature of oil labeled as synthetic. When your mechanic says regular oil help seal things up what he is saying is the oil forms sludge, probably mostly waxes that tend to plug things up. On the other hand, sludge interferes with oil getting oil in confined spaces in an engine so in my opinion his suggested benefit is outweighed by the downside. Mobil 1 is inexpensive at Walmart and when on sale, via rebate, it is downright cheap so there is no reason to not use oil labeled as synthetic.
Andy
Andy
97 993 C4S
I'm reaching out for a little peace of mind , over the winter had some work done at my local indie , complete tune-up , clutch , wires etc...also a couple of seals one of which was the front crankshaft seal , soon realized that it was leaking and the indie at their expense changed the seal and also did an oil change and added a mineral non synthetic oil , their reasoning being a non synthetic oil is beneficial to seals & gaskets & often stops small oil leaks , as I've owned the car since new and have only used synthetic oil should I be concern. Many many oil threads and I've read them all & as far as I can see no one uses anything but synthetic...I've just purchased mobil1 Vtwin 20w50 but wondering if I'm overreacting..here is the oil installed.cidF816B1D-145D-4D5E-9119-E7A3FB16AED8
Admittedly synthetic is more overkill than a necessity in n/a engines, It does flow better when cold and hold up better when overly hot but our engines especially in normal street use just aren't driven that hard and the oil temps are generally well controlled
for 993 original spec was different for syn and non
non
for normal summer use 15w-40,20w-50 or straight 40 w/ ZDDP 1100-1400ppm
syn
for normal summer use 10w-40, 15w-40, 15w-50 w/ ZDDP 1100-1400ppm
Both regular syn M1 and vtwin fit the bill
the only caveat is that the vtwin is formulated to accommodate wet clutches as used in most motorcycles, as such the friction modifier package is different, whether better or worse for our use I don't know
I do know that it's a lot more expensive and harder to get, so I just use M1 15w-50 in both of mine, going back 20-30 yrs or so
The canard about leaks is from the very early days of syn availability which was back in the 1940's for aircraft use, early examples lacked the components that would cause the automotive seals of the day to swell and thus seal. This issue was overcome w/ an additive package and hasn't been an issue for 40 years or so
Technical Guru
Porsche has ALWAYS and for every model, specified a range of oil weights by ambient air temperature. The bearing clearance argument that I keep seeing regurgitated on RL has always been complete BS. The factory delivered every 993 with synthetic 5w40 until 1996 when they switched to 0w40. And prior to 5w40, the 964 was delivered with non-synthetic 10w30.
You are entitled to your opinion wrt to bearing clearance but most engine builders I talk to don't agree w/ your opinion
Please tell us the source for this
yes, the 993RSRs, GT2evos and Cups were spec'd for M1 5w-40
964
993 owners manual
