classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
Thread Tools | Search this Thread |
#1 | ||
Rennlist Member Join Date: Jul 2002
Mike Cap 1997 C2 Arena Red/Classic Gray |
#2 |
User
Great info.
Thanks Mike ! |
#3 |
Addict & Guru
Rennlist Member Join Date: May 2001
Good job Mike. This has been on my to-do list since I bought my car. Your post may motivate me to actually get it done.
#4 |
Dan,
Thanks. I also finished fitting and mounting the TT bumper this weekend. It took me three weeks to get it out of the paint shop - they are all buried with work because of the bad winter and 120" of snow causing MANY accidents. I'll post some pics after the WX improves. My car looks just like yours now with the TT bumper and lowering.
#5 |
User
Hey All,
Any body thought of using the emergency cables to put electric remote release on the front or rear or both? I have not done it but I was only thinking about it last weekend. |
#6 |
Rennlist Member Join Date: Oct 2007
If I remember correctly there should be an emergency release for the rear as well,behind one of the
rear lights...
964 Turbo 993 RS GT2 |
#7 |
Rennlist Member Join Date: Jun 2008
This excellent tip was posted last year:
http://forums.rennlist.com/rennforum...d-release.html
1995 993 Carrera Coupe Black/Black 14k mi. FABSPEED, ltd. slip, Nakamichi/McIntosh/MBQuart 1998 993 C2S Red/Black, 44k mi. PSS9, RS Bars & engine mounts, Fister SSK/GR & Stage III, CDR210 PCA/BMW CCA Nat. Certified Instructor Other vehicles: 2005 MINI Cooper S, (2)2006 JCW MINI GP's, 1965 Shelby GT350, 1966 Shelby GT350, 2009 F150 FX4 SuperCrew |
#8 |
Rennlist Member |
Will these pics and text help....
Parts needed to make this engine lid back-up release: 1 - bicycle brake cable. 1 - bicycle cable casing cut to length by user. 2 - bicycle stainless steel cable casing ends. 2 - rubber caps (optional). 4 - cable ties. ![]() A close-up view of the rear engine lid latch where the OEM cable attaches to. The end is in view and it is held in place by a screw. The back-up cable release is fed through an existing hole next to the manufacturer's engine lid cable release. The barrel end of the bicycle brake cable is in view. ![]() The view of the engine lid latch from other side. The bicycle cable casing can be conveniently tied to the same bracket that the metal tube for the OEM's cable release is attached to. ![]() The bicycle cable casing is run along and under the existing metal tube and tied off with cable ties. ![]() ![]() The back-up cable release exits through the inner fender through an existing hole adjacent to the OEM rear engine lid cable release metal tube. The bicycle cable casing is cut to length so that if parallels the OEM rear engine cable release metal tube. The ends were filed square, the outside and inside edges are deburred. Compressed air was used to blow out any metal filings. Then metal cable ends were pressed on. The red rubber caps were placed over each end and were used to prevent metal to metal contact. OK, so I'm picky.
All the best, Alex A true driver's car does not have cup holders. ![]() HB sport seats, RSR exhaust, LCD voltmeter, instrument trim rings...and original everything else. 1995 Porsche 993 - Speed Yellow - my 42 year dream come true. Porsche 993 - Some DIYs & Info. Motorcycles & Alps Touring for those into motorcycles and motorcycle travel. |
#9 |
Rennlist Small Business Partner Join Date: Apr 2010
Good answer Mike, good info
For a factory Porsche solution, you can add the Porsche emergency release cable (some 993s already have this). As Budge mentioned above, it is accessible by removing the driver's side turn signal assembly. Part # 964 512 521 00 (about $11) For the 993 turbo: 993 512 523 00 For a visual, here is the parts diagram. See #11: |
#10 |
Rennlist Member Join Date: Oct 2004
I have a spare factory cable if someone is looking for one.
#11 |
Lifetime Rennlist Member Join Date: May 2001
Yup, I put a few in - not quite as inventive though, used stainless cable (sources from the Boeing Surplus Store when they were in operation so it could be 747 cable!), and followed the same path. Test it, works like a charm!
"Scarlett" - 1997 993 Arena Red Turbo - Sport seats, silver gauges, aluminum parking brake/shifter, 19" RUFs - and more to come. Gone but now living just down the street - 96 993 Polar Silver Targa Check out http://www.pcarworkshop.com |
#12 |
Rennlist Member |
Mike, I was going to run just a cbale, in fact the Porsche one (which is nothing more than the stainless steel cable you get at your hardware store), but decided to run it through a bicycle cable casing for a more finished look. In the end, I also used a brake cable from a bicycle as well which was looped at the other end using a cable crimp.
Having the cable run through a casing makes sure it stays out of the way of anything.
| Tags |
| 03, 2000, 2001, 2002, 993, 993tt, boxster, c4, cable, emergency, engine, hood, porsche, release, trunk |
