993 Forum 1995-1998
Sponsored by: DashLynx
Removing Shifter Ball and Closing a Frunk Properly.
Old 07-16-2019, 11:38 PM
Twilightblue28A
Twilightblue28A's Avatar
Default Removing Shifter Ball and Closing a Frunk Properly.
I want to replace the shifter ball (6 speed) in my car. How do you replace the ball and where can I purchase an OEM replacement, cashmere with a silver colored shift diagram.
Also, how do you close the trunk properly. I have been told to place my fingers on the crest while others have instructed me not to push on the crest, but instead, next to the crest on the paint.
Thank you.
Old 07-17-2019, 01:26 AM
paulkromz
paulkromz's Avatar
Old 07-17-2019, 01:37 AM
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
Twilight,
Taking the second one first, I was told and do put my palm on the crest and gently push until it latches. I am sure a few fingers works just as well.
As far as a replacement ****, the C4 **** is better and different than the C2. When I priced out a new boot and **** it was $286 (now $390) and blue leather I needed was out of stock. The C2 is about half as much. I believe they interchange but I don’t know and the shift pattern is black on a C2. You can check with your favorite Porsche parts supplier (dealers, pelican etc.) to see if they have a C4 **** and boot in cashmere. I was told by Porsche that if you order one, even if it shows out of stock, eventually they make one for you and ship it out, but I did not try as (1) $286 is a lot of money and (2) I liked the function first **** I ordered. I understand carbone in Poland will recover your existing **** and make a new boot for less money, but no personal experience.
https://rennlist.com/forums/993-foru...hift-****.html
Old 07-17-2019, 01:54 AM
Twilightblue28A
Originally Posted by evilfij
Twilight,
Thanks for valuable information. I will check Pelican to see if they have my shifter in cashmere. The next challenge is to get the shift pattern in aluminum color to match my car. I never knew the C2 and C4 shifters are different. Good information.
BTY: Matching blue interiors are extremely difficult if not impossible.
Old 07-17-2019, 02:00 AM
Twilightblue28A
You're link is also helpful. Does anyone know if I can buy only the cap and ball in cashmere? The car is a C4 which I just learned is a different shifter.
Old 07-17-2019, 04:48 AM
911PERVY
911PERVY's Avatar
You can not get the plastic shift insert on its own from Porsche, it is available aftermarket in real aluminum though!
https://type911shop.co.uk/epages/de8...6/Products/626
Old 07-17-2019, 08:17 AM
Twilightblue28A
Can I buy the cap and shifter ball OEM?
Old 07-17-2019, 08:42 AM
AOW162435
Seared
AOW162435's Avatar
Harry,
You purchased your 993 new, and thus have owned it for more than 20 years. And you’re asking how to close the trunk lid?
I trust this is a joke.
Andreas
Paolo1 (07-20-2019)
Old 07-17-2019, 09:11 AM
pp000830
pp000830's Avatar
Received 1,452 Likes on 1,023 Posts
I do something similar using my palm on the hood but not on the crest to avoid flexing it and cracking the cloisonne color sections.
Andy
Old 07-17-2019, 09:19 AM
P-daddy
P-daddy's Avatar
Twilight- on a C2 or C4, the ball and boot is one piece. You can’t replace just the ball.
evilfij (07-17-2019)
Old 07-17-2019, 09:20 AM
NC TRACKRAT
NC TRACKRAT's Avatar
Here's my method for closing the Frunk lid: Place the palms of your hands on the furthermost edges of the lid in a line parallel with the emblem and press down until the lock engages. This eliminates the possibility of damaging the emblem or causing an indentation to the lid surface.
Old 07-17-2019, 09:42 AM
Cowhorn
Cowhorn's Avatar
What do you do about the fingerprints you leave behind?
Old 07-17-2019, 01:00 PM
evilfij
evilfij's Avatar
Since the C4 **** and boot is a complete assembly, it comes with the aluminium color insert. Guess that justifies the $390 ....
Twilightblue28A
Originally Posted by AOW162435
Harry,
Andreas
I'll leave the answer to your discretion. You have to give me some credit for not driving twenty-five (25) years with the frunk open.......
Old 07-17-2019, 01:09 PM
NC TRACKRAT
...and I thought I had OCD! I said palms, not fingers...and I don't have sticky, greasy palms. The question was about how to close the "Frunk" and, to my mind, risk of damage to said "Frunk" is less with my method.
Quick Reply: Removing Shifter Ball and Closing a Frunk Properly.
