Upper dash access to radio
I'm installing a microphone for the bluetooth call feature on the radio. There is a nice factory hole in the dash just left of the speedometer that's the perfect size for the mic. My problem is that after removing the dash I can't find any access to the radio, the metal framework seems to be completely boxed. poking around with a wire fish hasn't revealed anything as well.
I have some ideas, but I refuse to be an accomplice in cutting holes in a 993's dash face. Nope nope nope.
Have you considered mounting on the right side of the steering column down near the dash? Easy access and no cutting.
I mounted mine to the windscreen inner rubber seal above the rear-view mirror and then channeled the lead through the seal across and down to edge of the dash to an access panel held in place by one screw and hidden when the door is closed. With the access panel off I was able to pass the cable through an existing hole, through the back of the dash to connect to the radio. Put the panel back on and you'd have to look really hard to see it. I'm my hardest critic and I was pleased with the outcome.
There may be a reason why in many cases the microphone is mounted high up not lower down in the dash. It may have to do with the engine, HVAC blower and road noise interfering with its function. i bet it could be put next to the mirror and the wire hidden behind the inner windshield edge running down to the radio as outlined above.
I have installed about a hundred radios in 964 and 993's and always install the handsfree mic in the roof between the sun shades.
Easiest way is to run the wire under the dash and through the little hole under the triangle lid (with one central screw) at the left dashboard end. Then, press the wire into the narrow dashboard panel split to the windscreen, and tuck the wire between the rubber gasket and roof lining.
Cheers,
Tore
Cheers,
Tore
I recently installed my Porsche Classic Radio and had the same problem. There is a small hole for the antenna that passes between the sheet metal that divides the upper and lower dash. With the radio out you can reach in and use pair of pliers to remove the rubber grommet for this hole, which should give you enough room to pass your wire. I routed both the GPS receiver wire and the bluetooth microphone wire this way.
Cheers,
Tore
Cheers,
Tore
Alternative route
I found a gap between the upper and lower halves of the dash that was just big enough for the mic plug to fit through. I needed to remove the screws from the top airbag mounting bracket so i could get my fingers in their. Nice thing is all that extra wire gets hidden under the dash.
