Which belt for this odd single pulley fan setup?
Hi-
Posting from Autozone parking lot after getting the broken belt light on the dash. Not enough of the belt is left to identify what size it was.
Seems the previous owner installed some kind of single pulley setup, I did search and read some of the RS pulley threads but the pulley in those pictures looks different than mine.
Is anyone able to take a look at this picture and tell me what size belt to get?
Thanks!
Thanks!
the main benefit is that you only have to change 1 belt, and no special tools required (12 point to hold the shaft being the biggest PITA). All you need now is a 10mm socket to undo the pully.
Downside... It does not charge the battery below 3k RPM... so sitting in traffic for long periods of time could be 'problematic", so find a side street and rev that **** UP!!!
- If the original poster plans to street drive his car.and
- Even at highway speeds in 6th gear, the rpm doesn't always crack 3000 rpm and
- We know the narrow 9.5 belt is overstressed and so prone to failing at the side of the road pulling just the alternator alone, not even considering the added load from the blower for which it was never designed.
Andy
