Rear brake light "escaped"!
I was out for a fun drive with friends yesterday and had to pull over at one point to acknowledge the frantic headlight flashes from behind me.
It turns out the driver's side rear brake light assembly had escaped from it's intended location. It was caught quickly so no paint damage, the connector remained attached, and miraculously the screw remained captured in the housing. I happen to keep a small phillips-head screwdriver on my key chain (for just such an emergency) and things were back together quickly.
I check these screws at intervals, but must have let it go too long this time! So I'll offer a PSA to check those screws are tight the next time you are out. Does anyone recommend maybe using Purple or Green LOCTITE here, to minimize the chances of the light falling out?
you should have a phillips screwdriver in your cars toolkit as well.
Thanks for the heads up though I will check mine
The turn signal/brake light housing is secured by tabs on the inboard end and a single screw at the outboard end. The screw goes into a "speed nut", that is easily dislodged from its correct position. When that happens, the screw goes into a plastic hole, with nothing to really "bite" into. Bottom line, make sure the speed nut is correctly positioned before replacing the housing, and feel carefully as the screw tightens, but don't overtighten. Good idea to check these screws from time to time.
If the speed nut is loose, it may help to remove it and pinch it a bit with pliers so it fits tighter onto the plastic.
Loctite or similar won't help in this application.
SpeedyC2 (03-02-2020)
Yup, I had a lamp try to run away once, held back by its leash too. It doesn't help to try to make the hold down screw tight as one will simply crack the lens. Could put some low strength thread locker or something called after-lock on the screw threads. This might help those who have a concern.
Andy
Andy
I had the same problem... except my leash let the light hang on the exhaust tip, and melted the bottom of the light. worked fine for a year, till I got around to getting a new one....
SpeedyC2 (03-03-2020)
Well - of course I had the same issue (on the opposite side) of my car. I stupidly over tightened the screw and cracked the plastic resulting in me buying a new pair (and only needing one) —
it’s the circle of life.
Yup common issue on track use 993s too (WGI for me). Gorilla tape over the screw hole helps keep the screw from backing out enough to let the lens come lose, but you will see the tape “pimple” up when it dose start to back out.
After having this happen I "theorized" that the screw had come loose because of vibration.
I put a rubber o-ring on the securing screw to reduce vibration, add some clamping force between the screw head and the plastic of the brake light, and also to keep from overtightening the screw and cracking the plastic. The o-ring is just big enough to fit like a washer under the screw head.
This might not work for everyone but has worked for me for several years now.
Glenn
Glenn
Glenn
Glenn
The road we were traveling on when the light popped out was rough. I do think the extra vibration helped the screw back out, or the screw had already backed out and the vibration worked the inner tabs loose from their connections in the center reflector.
I check every few months, but apparently it was not enough.
Yup. Happened to me about 2 years ago on the highway. Didn't notice until I pulled into the garage and at that point it was already melted.
