Engine Fan Touching Housing
I replaced my engine cooling fan as part of preventive maintenance. The old fan had some cracks at the base of the blades that made me nervous. I purchased a new fan. It's a genuine Porsche part. I installed the new fan today and I can hear a very slight "tink" sound when I plip the throttle. I used the old belts and the same number of spacer shims when replacing the fan. I put a feeler between the fan and the housing and the fan blades are closer to the housing at the bottom than the top. It did not appear the fan touched the housing when the car is not running. Is there any way to adjust the fan so it is better centered? Any though are welcome. Thanks.
First, check your belt tensions using a belt tensioning gauge. Too much tension is not only bad for the fan & alternator bearings but can cause fan blade clearance issues.
Dayco Belt Tensioning tool
The belts may be too tight. I would not have though this to be possible because I used the same shims and belts. Given that the fan is being pulled down, it would make sense that the belts are pulling the fan down. Now I need to figure out how the shims work. As I understand it, I need more shims as more shims somehow loosen the belts.
Correct. As you add shims, it spreads the pulley halves allowing the belt to sit lower.
Tighten the 4 nuts at the back of the alternator. These not only secure the black plastic cone in the back, they make sure the alternator is secured squarely to the fan shroud. Your blades rub the fan shroud because every time you blip, you’re pulling the alt/fan down thus making contact.
I would check the bearings on the alternator, if worn they will allow the fan to be pulled down by the belt to make contact with the housing. Had the same problem with the fan, cracked and split on the ends. A new fan and new alternator bearings fixed it.
Hi GTA,
Two or three 0.5 MM shims 964-106-268-30
Should give you a good range of adjustment.
While you are at it buying
Andy
- a couple of extra: square AC compressor hold down nuts 964-126-311-00 and
- a set of inner pulley hold down screws, 6x30mm socket head cap screws 900-976-004-01;
- 999-192-343-50, 9.5 X 760 (outer alternator).,
- 999-192-338-50, 9.5 X 776, (inner fan)
- 999-192-363-50. 13 X 1085 (AC Compressor)
Andy
there should be torque settings for those alternator nuts, as well on the band that holds the fan housing in place. it is easy to overtighten these and then things can get out of whack,
- Frank
- Frank
Another less likely (but possible, as it happened to me) option is the fan shroud has cracked at the mounting points and has warped slightly out of round.
