Replacement windshield - help or hurt value?
I have a 96 C4S. Its in good shape with 50k miles and all original. I like to maintain & improve my cars but keep them stock, or at least easy to put back to stock in the event I ever want to sell. My windshield has some pitting that really bothers me when driving in the sun. I am curious on the consensus - does replacing it with OEM glass hurt the value or not a big deal?
Polishing pits out of auto glass is very common. If one does an internet search all sorts of products and how-to pages come up.
Here is one I found interesting:
Andy
The following 5 users liked this post by goofballdeluxe:
71-3.0-911 (05-07-2020),
993c4_Toronto (05-11-2020),
ashephil (05-08-2020),
gt3'er (05-09-2020),
luv2race (05-09-2020)
this was almost the first thing i replaced on my 993.
it's a safety issue and there are no downsides as long as you have a good company do it.
(seriously, though, don't touch the car until the glue has dried. don't move it an inch. don't open and close the door.)
LMAO!! I just replaced my windshield out of necessity- it broke when we took it out to grind out a rust spot in the channel ( the usual areas these cars get rust). $ 1,100 for the glass, seals, new trim, etc. Looks awesome though.
When i bought my 96 4S in 2007, it DID have the original front tyres!
When i bought my 360, the tyres were 9 years OLD.
What's up with some people????????????
In Mass glass is included with all policies.
Had a small crack that spider webbed. When I called insurance company (Geico) to replace, they offered OEM, without the little "P in Triangle". After a few weeks of negotiation, arguing about diminished value, etc. They finally agreed to original glass. It was 2x the cost.
And here is the best part.
About a month later, had the car wrapped. For what ever reason, forgot to ask to get the small metal strip under the windshield included. Driving home, a small rock bounces off that piece, left a tiny scratch, and then a tiny divot on the brand new windshield.
Called insurance company back. They read thru the file, and told me to basically ****-off.
Switched insurance companies a year later. Waiting for a few more dings and then will try my luck again!!!
Hi Toona,
My understanding is that all the glass is made by a German supplier who supplied the factory. If one wants the P-Triangle symbol maybe one can;
Andy
- Create a clear mailing label and print it and stick it to the inside of the glass or
- Go to one of those custom label web sites and upload the graphic and have one print a nice one on clear body guard material. Otherwise
- One could make a template and acid etch the symbol in the glass and then rub it with black nail polish to pick up the color.
Andy
Having recently been through some windshield glass nightmares, I can tell you matter of factly that not all glass is made by the same German supplier, so let's not perpetuate that inaccuracy as reading that here actually led me to make some bad purchase decisions.
Yes there is Plinkton or Sekurit glass available that does not have the \P/ triangle. Both of these were OEM suppliers for Porsche. They are available on the aftermarket as OEM replacement but lack the \P/ logo. If you purchase direct from Porsche, they come with the logo.
There are at least two other sources of glass, both of which will lead you to some headaches. At least one is made in China and both do NOT come with the channel trim bonded to it which the outer seal presses into. This part is not available from Porsche, is notoriously fragile (leads to complete windshield replacements) and yet these companies apparently expect that if you are replacing your glass that this part can somehow safely be removed and reused without damage.
High level summary of my saga:
- new to me 993 showed up from California in NJ
- front glass was leaking (installed in California and was less than a year old)
- discovered the glass was not bonded, instead was sitting loosely in a 964 gasket (WTF?!)
- glass did not have the channel for the 993 outer seal (it was just bare glass)
- assumed it was 964 glass but turns out it may have been Chinese 993 glass (it was made by a company that I could not find a SINGLE reference to on Google BTW, odd?)
- glass from Porsche $1300, glass from Safelite $900, glass from the local reputable glass shop, owner lives around the block and was giving me a discount: $350 installed (what?!)
- RUMORS on RENNLIST: its only made by one factory, its the same glass, just missing the \P/
- $1000 extra? No thanks!
- ordered the glass from the local glass shop, questioned the price and asked if the glass was used.. "no, it's brand new. $1300 for glass is crazy. Is there diamonds in it?" they mock...
- shows up, guess what? No channel bonded to the glass for the outer seal?!?
- brand was different then the glass I already had on the car. This one was made in China "WuZhang" or something
- tell the glass shop this cant be used, there's no channel, channel should not be removed from old glass and also I don't have it and it cannot be purchased separately
- they're speechless and tell me I need to go to Porsche then and hand me my deposit back
- skipped going down the Safelite route, as who knows where the local Safelite is sourcing from?
- $1300 to Porsche later, I installed my own Plinkton glass myself with the \P/ logo, with more care than anyone else would have taken for me (to level set, I DIY absolutely everything; one of those types)
Thanks again to mike cap on here for letting me borrow his windshield gauge tools!
TL;DR - Buyer beware purchasing anything other than glass direct from Porsche. Not all glass comes from Plinkton / Sekurit. If you cant confirm it is those brands (with or without the \P/ logo... RUN!!!)
M. Schneider (05-11-2020)
Few years ago I had the windshield on my C4S replaced by Safelite. They did a spectacular job. They ordered the correct Made in Germany Pilkington glass (no P logo), and Porsche inner and outer seals. I was very happy with fit and finish. My $.02
