Headlight/Fog Light Upgrades
#76
@rgupta250 or @Goose 993
looking the Morimoto diagram the pair of black/gray wires connected to the H1 bulb are left unused on both sides?
and RH side has no wires going to the OEM low beam connectors?
#78
I went with the BergvillFX High Beam LED and HID Low Beam and finally got into the install today. Huge kudos for the thoughtful design and ability to install cleanly into the original housing. Unfortunately the low beams were a bust. High beams work well. When I installed the low beams and game them a try, all looked to work okay at first although I kept thinking that I saw a ever so slight flicker going. Next time I turned them on the passenger low beam was flickering significantly. Took the car for a ride and after a few minutes the driver side low beam stopped working all together. Pulled it back into the garage and then the passenger stopped working all together. Pulled out the HID Low Beams and put the stock bulbs back in for the time being. High beams still work (and are a huge improvement). Need to sort out this Low Beam BS though as visibility with the stockers is terrible!
#79
