Headlight/Fog Light Upgrades
After tackling my suspension and shift linkage, I want to address the 25 year old lighting technology on my 95 993 Coupe.
These are my desires:
RG
- upgrade low beams to HID or LED
- upgrade high beams to HID or LED
- upgrade front running lights (inside fog light assembly) to LED
- upgrade fog light to HID or LED
- want the light color and intensity to match across all light items (4500K to 5000K ideally)
- want to retain independent functionality of low, high beams as well as fog lights
RG
I've driven 993 cars with both the low beam Halogen and HID's (Litronics). The Litronics are far superior. Its pretty cool that LED's are now available. Haven't tried those, but I'd imagine they are equal or better than the HID's.
Depending on the country/state in which you live, you may be limited as to what you can do to your car, so as not to inconvenience others.
If you want to be able to see properly, in the dark, then IME the best path to tread is Tore's HID plus new projectors from Morimoto with the solenoid to lift the low-beam cutoff 'bar' out of the way when you wish for full-beam. Full-beam bulbs are then irrelevant..
I just did the T-light 4300k low beam kit with the Morimoto (the retrofit source) projector housings and it was great, as many other posts on here say. I did not do the LED in the high beams but that has some good reviews as well.
https://www.bergvillfx.com/products/...-hid-kit-4300k - ballasts, bulbs kit
https://www.theretrofitsource.com/mo...993?quantity=1 - projector and hardware
Oh, well the fog lights share the housing with the front parking/marker light and the t-light kit comes with two led bulbs for those. I never use my fog lights but that is something you can possibly get an led bulb for as well. I would call bergvillfx as he is really helpful. Tel: +4798215245 https://www.bergvillfx.com/contact_us
I was looking to fit another set of spotlights or driving lights, even extra ones as per the rally cars, as visibility was so poor on full-beam, but once I had the Morimotos, there was no need.
I prefer the old-skool yellow light in foggy conditions, so I sourced halogen yellows. That way, you don't need to match the colour of the 'white' lights.
Gjbacci (12-05-2022)
But you'll never see the foglights, so just put decent bulbs in? Or do you mean you want to change to more of a spotlight?
That’s a good point. I’ll will probably change out the low and high beams out first and then see if I need to address the fog lights.
RG
I’d be interested if anyone has found LEDs for the fogs, these seem to be challenging and limited that even Tore doesn’t offer such an upgrade.
Installing an HID kit has been done, but would prefer to avoid that option.
Knight - I agree with you. All my research resulted in finding out that there is no acceptable LED upgrade for the 993 fog lights. The challenge is that the fog light bulb is a H3 halogen bulb with a unique connection and very little room behind the fog light housing. That being said, there is hope. I spoke with Tech Support at The Retrofit Source (vendors of the Morimoto Bi-Xenon projector lens) and they will releasing in January 2021 a new ‘plug and play’ LED fog light solution for the 993.
The owner is a big Porsche fan and owns a few of them. Fingers crossed that it’s what we are looking for.
RG
Tried to get a quick snap yesterday, but the LED white lights affect the photograph/exposure so the whites look brighter in the photo than they actually are and drown-out the yellow halogens, if that makes any sense.
Look at the light on the ground - it's yellow!
Since there are threads on how to take the fog light apart to replace the lens and/or refinish the beige plastic,
https://rennlist.com/forums/993-foru...lamps-now.html
it might be also possible to remove the H3 projector entirely and put a new LED fog light assembly inside the housing- here's a pretty small one.
https://www.superbrightleds.com/more...0-lumens/1699/
1. Is the Morimoto projector a plug and play fit or were modifications to the headlight housing required?
2. Did you use the optional Morimoto "High Beam Splitter" to activate low and high beams at same time?
3. Did you use the optional Morimoto relay harness?
BTW, Tore is working on an LED solution for the H1 high beam and it may come out soon.
fnckr (02-20-2023)
