the tiresome topic - Porsche 993 Tequipment handbrake alu lever
#31
Hey guys, speaking of these, does anyone offer leather boot replacement on the shift **** itself? It seems to be integrated/all one piece. I just purchased a '97 C2 and it came with the same handbrake and shift ****.
Thanks!
Thanks!
#32
For fun as I was looking for that brake handle I remembered I had all of the literature for 993's so looked at how much they cost from Porsche back in the day... $850 new. Wow, surprised so many were sold.
Kicking myself for not pulling mine out a couple of weeks ago 😕.
#33
Man $850 back then! Expensive!!!
#36
There is a lot of demand for these items. Given the commitment from Porsche with classic parts I wouldn't be surprised to see these reproduced at some point in the future.
#37
Same here. I didn't want any silver parts in my interior. Took mine apart, powdercoated the pieces and filled the lettering in white. Also upset some people, I'm sure.
In hindsight, I plan to redo the shift pattern in satin black to provide some contrast against the mini-wrinkle black. Will be making a run to the powdercoater soon enough.
YellowDieselGolf (01-15-2021)
#38
How do you get the cap off of the **** without damaging the alum surround?
or is that inevitable...???
So how much does the carbon **** and brake go for in mint condition?
#39
Definitely do not try to pry on it as it will not help and you will definitely destroy both aluminum parts on the shifter. To take it apart, follow theses steps:
- Remove the entire shift ****/boot from the car:
- push down on left side of boot base to remove from two clips in console
- slide base of boot to the left to "un hook" it from right side of console
- angle boot base to remove it from opening in console base
- lift boot up to expose allen screw at from side of shift ****
- loosen allen screw to remove shift ****/boot from car
- With the shift boot/**** out of the car:
- Use a heat gun to warm up the glue (epoxy) which is holding the shift pattern insert (apply heat directly to top)
- Take a long, skinny screw driver and insert it up through the shifter shaft opening
- You will want to move it around until you feel it enter a small hole in the larger aluminum piece and make contact against the bottom of the shift pattern. (see the circled opening in pics below)
- With the screw driver held securely in that hole, bang out the pattern (gripping the underside of the shifter while holding the screwdriver and banging the screw driver base against the floor or workbench will make it pop off)
- Once the shift pattern insert is removed, it will expose two screws which hold the second part to the rest of the shifter/leather covering
The following 4 users liked this post by boomboomthump:
#40
#42
#43
Seared
That is a 996 shifter! Looks like the one in a 996 GT2 I drove awhile back.
#45
similar to -> http://www.carnewal.com/products/993...eather-Shifter
