Door seals - what gives?
So firstly, many of you may remember that up until about a year ago the price of each door seal was ~$600 (first sticker shock I got when I took delivery of my 993 in Jan of 2020). Around this time last year, the price came down considerably to $300/ea or so (believe Andy or someone posted a thread about it).
Last week I ordered new door seals from Delaware Porsche. Items: 964-531-095-00 & 964-531-096-00 both of which were available for $216 each (discounted price). My order shipped today and it included 964-531-096-00 but 964-531-095-00 was substituted with 911-531-095-03, which was only $120 vs $216.
Here's where I'm scratching my head...
964-531-096-00 description reads "door sealing frame right; for use on 993 Coupe 1994-1998"
964-531-095-00 is now replaced with 911-531-095-03 (this only changed in the last week; I was able to order the 095-00 part a few days ago)
911-531-095-03 description reads "Door sealing frame; for use on both sides on Porsche 911/ 911 S and Carrera 3.0 (1974 to 1977), 911 Coupé (1978 to 1989) and Porsche 964 Coupé (1989 to 1994)"
A bit perplexing and will be interested to see if the seals look visually different from one another. If they do, I will not be able to sleep at night!
- why does this only apply to 94-98 if it is a 964 part?
- Why would this not apply to 964's?
- LINK
- This seal can be used on either side yet above part is right side only?
- This has no mention of 993
- Why is this half the cost of the other 964 part number for right side door (that apparently is only for 993's)?
- Why has the above right side door seal not also been replaced with this part number which apparently can be used on either side?
- To further complicate the matter, this part number also says "NLA - no longer available"... what the heck?!
- LINK
M. Schneider (06-02-2021)
I agree, it makes no sense. Especially using the same one for both sides. I'm interested in what you actually receive.
A few years ago I replaced mine & also was shocked. At the time Targa seals where $800 plus. They fluctuated so much in 6 months time, I was able to get them in the $300 range.
Many 964/993 parts are interchangeable and have seen this on other parts as well. Kinda goofy!
mhm993 (04-14-2022)
The door seal appears to have always been a 964 part number for the coupe. An updated design around the window frame probably to reduce air noise or lower the air drag coefficient of the body even though the body opening may be the same as the earlier '80s cars,
I buy the earliest 911 part number on eBay, $30, save some money, and then cut a section out of it to repair the threshold that is the key wear area on the door seal. By doing this I retain the better sealing version that came on my 993 up around the window frame where the seal has proven to be very durable. I also end up with enough material to do two or three threshold seal refreshes.
Andy
Andy
Not sure about now, but back then these things seem to fluctuate like the stock market.
911-531-095-03 description reads "Door sealing frame; for use on both sides on Porsche 911/ 911 S and Carrera 3.0 (1974 to 1977), 911 Coupé (1978 to 1989) and Porsche 964 Coupé (1989 to 1994)"[list][*]This seal can be used on either side yet above part is right side only?[*]This has no mention of 993[*]Why is this half the cost of the other 964 part number for right side door (that apparently is only for 993's)?[*]Why has the above right side door seal not also been replaced with this part number which apparently can be used on either side?
Andy
The original 911 seal from 1974 on was the same form factor all along its length and simply had its ends welded together at 90 degrees so it could simply be turned around and used on the left or right side of the car. This is also how it was done on my 1986 Carrera. It will probably fit any 911 1974 to 1998.
What *is* different (and I just confirmed with my old seals), inside the "puffy" part of the seal which compresses (not the part the goes in the channel) there are several stiff rubber inserts. The original 911 part number has one of these as well at the exact mid-point of the seal. The 964/993 seal has two additional inserts. One is at the very top of the A pillar, along with one at the bottom (mid-point of the seal) and one around the bottom of the door jamb. Comparing my old seals, the left to right have these inserts at the exact opposite positions side to side. Beyond that, there is no difference and they can be installed either way.
Now here's some pics of the conundrum. You can see the 911 seal looks substantially different being it is ribbed (queue someone to drop a Trojan joke). Additionally, the 911 seal is substantially smaller in girth (aye, we're on a roll here).
So if the left side 964 part number is really NLA, this is one hell of a crappy situation. I'm calling them tomorrow to return the 911 part number (not what I ordered). I will then be on a hunt for some place that has the left side 964 part # in stock. Alternatives will be some other aftermarket supplier that has the correct style seal (if any exist) or lastly, just run a right door 964 seal on the right side and live with the fact that those inserts are in different places.
As much as I hate paying more, Pelican Parts to the rescue. They had 4 in stock and I just snatched one up. $289 plus tax and free shipping, $309 out the door. If anyone is in need of door seals, might want to jump on the last 3 if these left side door seals are truly NLA. Though I really hope Porsche sorts this situation out.
Now I just need to return the 911 part number that was substituted by Porsche.
Not correct. There is nothing different at all in the "welded corner" of the 964/993 seal. It can be reversed just the same and installed either way.
Now here are some pics of the conundrum. You can see the 911 seal looks substantially different being it is ribbed (queue someone to drop a Trojan joke). Additionally, the 911 seal is substantially smaller in girth (aye, we're on a roll here).
The two times I purchased seals I purchased them on eBay. Both presented as fitting all 911. The first had the ribbed compressable form you describe and worked fine to replace the threshold section, the second one purchased years later when the threshold was showing use had the smooth rubber compressible form. They both worked just fine on my 993:
https://www.ebay.com/itm/370891755651
Fixing the seal just doesn't seem to be such a big deal?
Andy
