993 Crew - Gearing Change Input - Yes another thread
97 C2S
I'm at a cross-roads. So thought I'd put this question out there. Yes I've read the existing threads recently, numerous ones from years gone by.
Context - I bought my car without driving it. Couldn't cross border to see the car in person. I did have a PPI and the shop pointed out there is a random issue with second gear, they felt probably requires new synchro. I saved a bit on the deal but knew that those funds would likely go to resolving the issue. Car is fantastic otherwise. So bought it. Transmission is being opened up today because I don't like the random second gear issue and want to resolve it. Doesn't want to shift into second from third at times.
BUT.....I've been reading re-gear threads. So now's a good time to get that work done to save investing in stock parts now and the re/re costs should I want to do it later. Save some to spend a lot more though.
My fear is loosing the 993 feel by re-gearing. I really enjoy my air-cooled cars, mostly for what they are. Mostly, because I have modified a few things. Re-gearing will change how the car drives, that is a fundamental change to me and not how a 993 was intended to drive (I say intended, because that's how the car shipped).
Any re-gear folks......can you share your feelings with them now? Some of you would have had it for years based on past threads.
Open to other thoughts as well.
ADDITION - Would you do steel synchros? Brass seem stout enough for the most part. Mixed reviews on RL on this aspect as well.
I haven't re-geared but seriously thought about it twice, to fix the 1-2 ratios. IMO the /21 box is how the 993 was intended to drive, the /20 is a compromise.
In retrospect I should have brought a G50/21 back from Europe in 2005, when they were about $5k, because the cost of re-gearing even just 1-2 when I had my trans rebuilt in 2019 was Very High and I couldn't find a /21 or removable-2nd shaft anywhere.
Why didn't you do the re-gear.
Re-gearing was just too expensive in the scope of the the 2019 refresh. Engine-out service (7k in parts, my labor), a bare-metal respray (15k) and a trans rebuild to fix the graunchy 2nd gear (7.5k). The piggybank might have stretched for a /20 second gear but I couldn't find anything I could afford.
He gave me the original gear set, which I’ve kept submerged in gear oil the last 15 years.
ed devinney (06-24-2021)
That's another interesting point, value. I don't intend to sell the car and I'm typically of the camp to not worry about what happens at sale time. Prefer to have the car the way I want it. I of course don't do outrageous things anyway. But I wonder whether a 993 buyer would want a regeared or original ratio car. If regeared I would assume no value assigned to it later (as worst case scenario).
Car had what I believe were original mounts. I did replace them with RS mounts. I also replaced the slave cylinder, flushed clutch hydraulic and transmission oil. Tried a few things that I found on RL, past recommendations from Steve Weiner. Also the input shaft is not rusted or dry. So left with opening the box up for a look at this point.
Just say no! Regearing the transmission, although regearing can enhance the driving experience for some by moving the shift points, it is an expensive modification. One may be better off learning to value the virtues of the stock, tall 2nd & 3d gears when driving in traffic.
Andy
Andy
Re-gearing (complemented by a few other related modifications) makes a 993 come alive. If you are opening up the transmission anyway then yes, absolutely do a re-gear!
SToronto (06-24-2021)
This was also my story. My car was graunchy 1-2 but not bad 3-2. It was that way when I got it at 37k miles, Soon after it needed a clutch and we saw that the one in there wasn't original, so the first 37k miles must have been pretty hard. No oil or adjusting fixed it, and the removed synchro told the story.
Over the hump I don't regret leaving the gearing alone when balanced against cost. The rebuild + Porsche/Mobil PTX unicorn tear oil + Fister SSK-Goldenrod combo were transformative to enjoying the car, which I already enjoyed immensely.
Watching recent sales, your point about value seems spot-on. We 993 nerds might slaver and even pay extra but on the whole the market doesn't really reward re-gearing.
I would definitely like to re-gear. Pretty much the only thing that bothers me about the car.
fatmike (06-24-2021)
Andy
Andy
I don't find myself in much traffic as it's a fun car not a DD or regular driver. Talking like 3-5,000 kms a year.
Expensive for sure and if you don't like it for whatever reason...wow. That's why I decided to post this thread, just for some further discussion.
