Are my ignition coils bad?
#31
Whats your battery voltage before and after you start the engine?
Lets do some tests and see what gives. Answer the questions above and we'll work through this with you. These are very robust, reliable engines. 9 out of 10 its a deferred maintenance issue. The key point is to test the module to ensure it has failed before replacing it.
I'm up for some vicarious virtual wrenching this weekend.
<edit> BTW, I have exact same car
#32
#34
Sorry for not updating about this case. The problem was the leaky intake stacks. I changed all 6 of them with new gaskets and it is running fine since then. It has been more than 6 months already.
Thank you for all your advices. Really appreciated!
