best choice of fuel - 90 (no ethanol) or 93?
HelpMeHelpU (11-12-2021)
I’d say if you drive regularly then ethanol is not such a concern. If the car is parked for months at a time then the non-ethanol would be better.
(edit) it will be hard to completely purge your tank of ethanol gas if you’ve run it before. Each fill just dilutes it, maybe a couple of tanks would flush most out.
I only use Rec 90 / non-ethanol gas in my air cooled cars.
Received 5,391 Likes
Buy the highest octane you can find from a busy national chain gas station. Don't over think this.
The following 3 users liked this post by LexVan:
This is from the Porsche UK website
The fuel types Regular E10 (91 RON) and Unleaded E10 (95 RON) are not suitable for use in the following Porsche vehicle types:
Type Year of construction
356 1950-65
911 1965-89
912 1965-69; 1976
964 1989-94
993 1994-98
959 1988-89
914 1970-77
924 1976-88
944 1981-91
968 1991-95
928 1977-95
These Porsche vehicles may not be run on E10 fuel.
356 1950-65
911 1965-89
912 1965-69; 1976
964 1989-94
993 1994-98
959 1988-89
914 1970-77
924 1976-88
944 1981-91
968 1991-95
928 1977-95
On this side of the pond I can easily buy 98 Octane - which I favour - or you sometimes see 100 Octane. I've always wondered how a 'chip' would perform on these higher octanes.
Try E30 with a tune. That would really wake the engine up!
So much to say on the subject but simply put both extremes of E10 and E85 have short comings. Since this is a E10 question I’ll focus on that. The trouble with such low blends is phase separation. When the moisture content of the fuel exceeds the ability of the E10 portion to hold it phase separation occurs. This is the foundation of all the ills most experience with ethanol. The higher blends like E30 and above don’t have this problem.
When considering E10 fuels one must think about their environment. Cold damp UK is a completely different problem than somewhere like Arizona.
INTMD8 (11-11-2021)
To each their own. E10 is not something I’m interested in using in any air cooled car I own. Here in the mountains of Utah, I use ethanol free 88 instead of the 91 (highest octane offered) in my older cars. At 7,000’ altitude it is quite fine, as the air is less dense and the engine makes less power. I don’t want ethanol gas in my tanks while my cars are in hibernation for winter. Even at sea level in Florida, I use ethanol free 90 over 93.
To the OP’s question, it really depends on your use. If you drive your car frequently and it never sits or is stored for the winter, ethanol 93 should be fine. If your use is seasonal, I would recommend avoiding ethanol gas. Pure Gas is a great app that will show you the nearest gas stations with ethanol free gas.
Last edited by L39E; 11-10-2021 at 05:31 PM. Reason: corrected bad info on air fuel ratio
Also, there has been lots of talk of ethanol causing problems, however, I have not seen a discussion recently where 993 actually has experienced such issues. If someone would describe a personal experience where ethanol was the proven root cause for a fuel system problem on a 993 please reply. Key here is proven not suspected. Also how it was proven would be a great addition.
Andy
This from my Bimmer. West Texas, oil country, and nothing over 91 octane. I normally use 93. Saw a significant drop in MPG. Car ran fine, just about 10% less MPG. Only other time was a fillup in Iowa, the navel of the ethanol universe. The supposed 93 octane, 10% ethanol (I think much higher) gave horrible mileage. The ethanol scam is the one that bothers me most. The politicians and producers love it ... and for good reason ... but it's not good for the car owner.
